Home > Puma (Tdci) > Bolt fouling hose
IanW
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zambezi Silver
Bolt fouling hose
MOT on the truck today. Passed, but on looking underneath with the tester a bolt on the steering column uj is fouling the hose immediately adjacent when the steering is turned. Anyone else come across this, and is there a cure? The hose is slightly scored. It can be replaced obviously but a longer term fix is needed. Would appreciate any thoughts. Didn't think to take a pic at the time unfortunately. Ian One wife - livid
Post #530399 10th May 2016 4:20pm
Some hoses in problem areas have a woven protective sheath on them.
On my 90 on a radiator hose that passes next to PAS header it is against it, it has a protective sheath on it.
Post #530403 10th May 2016 4:56pm
IanW
This one doesn't appear to have that protective sleeve. Just back from the village garage who will order and fit a replacement hose and make up some kind of bracket to keep it clear in future. Always something different with a Land Rover problem! The hose was worn through to the start of the canvas so glad the tester spotted it. One wife - livid
Post #530412 10th May 2016 5:56pm
Yes, a very common problem indeed. The hose connects the turbo to the intercooler and will eventually fail with a dramatic effect on performance!
The solution (on a 2.4, at least) is to be very careful when fitting the hose, and make sure that it is positioned clear of all obstructions before tightening the hose clips. Positioned correctly there will be no problem.
Post #530488 10th May 2016 9:40pm
Blackwolf - Could you advise on exact location of this hose?
Mine has had no issue, but may pay to check that one won't be happening in the foreseeable?
Post #530493 10th May 2016 9:48pm
Look between the air filter housing and the turbo, and you'll see the hose that runs from the turbo to the lower corner of the intercooler. It is actually quite hard to see. The problem is that if the hose has been carelessly fitted, the pinch bolt that secures the steering column lower shaft to the steering box will rub the hose as the steering is turned. Since you really cannot see the bottom of the hose at all, the best thing is to feel the hose and check that there is sufficient clearance between it and the bolt.
The 2.2 has a similar problem but due to the different design of the hose requires an additional support bracket to be fitted. The 2.4 is fine provided that the hose is properly positioned.
Post #530512 10th May 2016 10:15pm
LoveTheMud
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Santorini Black
any pics with a novelty arrow paint-shopped in please?
Post #530515 10th May 2016 10:19pm
BW - Thank-you.
Post #530518 10th May 2016 10:26pm
Pickles
That sounds like the turbo hose that was the subject of a recall,...should now have a bracket around it to stop it fouling the knucle on the steering shaft?
Pickles.
Post #530522 10th May 2016 10:35pm
Another option is to get rid of the rubber hose and replace it with a stainless steel hose like the entreq or another lesser brand
Post #530541 11th May 2016 5:58am
Pickles.
The recall was only on the 2.2, not on the 2.4.
Post #530555 11th May 2016 7:26am
IanW
Many thanks all for these helpful posts. Taking the vehicle back to the garage later for a further look to make sure they order the right bit. One wife - livid
Post #530560 11th May 2016 7:50am
I checked mine today whilst fiddling around, I can see it is very close clearance but not close enough to touch.
So I'm okay on mine but I can see why it could be an issue. Only around a 5cm gap.
Post #533711 22nd May 2016 2:32pm
IanW
The garage changed mine on Wednesday. It was scored by the uj bolt but not quite right through. The mechanic said that the replacement was a bit shorter and braided as reinforcement. He was going to make up a bracket to maintain the clearance but didn't need to in the event. Glad the mot tester spotted it. One wife - livid
Post #533772 22nd May 2016 6:07pm
5 cm is two inches, a massive gap! 5mm is more common.
Remember the hose can swell under boost.
Post #533840 22nd May 2016 9:02pm
