![]() | Home > Puma (Tdci) > Steering damper |
Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 837 ![]() ![]() |
I had the same thing on my old 110td5. I fitted an "uprated gas steering damper" I can't recall the make now but it was driving me bonkers pulling all the time( I can't remember if it pulled left or right) tried in vain with tracking etc then one day I took it off to fit a steering guard and ended up running it without just to try and hey presto all was good again.As far as I could tell the gas was to higher pressure and wanted to force out the piston out all the time which in turn put pressure on the steering making it pull. I sent it back, got a refund and fitted a standard one on at the time and didn't have any issues. I'm running a terrafirma one with a spring now and if you don't set the spring correctly it can do the same
