Home > Technical > Car suddenly doesn't start
scotty38
England 2012 Defender 110 Puma 2.2 USW Aintree Green
The car (2011) has not been in as regular use for the last couple of months but it has been used at times with no bother.
It was used maybe 5 days prior and then on Saturday morning it wouldn't start. I can't remember the complete range of noises (nothing major) but the one that stuck in my head was the repetitive clicking.
Used my battery jump start on it and all was fine. No further issues and started just fine again after a 10 mile run to the chilli farm.....
I haven't used it again since Saturday and I've not done any testing but off the top of your heads, any ideas what it may be?
Post #530064 9th May 2016 10:00am
Check battery earth is tight. Thumbs Up
Post #530072 9th May 2016 10:28am
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
Clicking will be starter solenoid probably, due to insufficient charge in the battery. A 10 minute run is probably not enough time for it to charge properly. get it started and take it for a good run, should allow the battery to be charged more.
Post #530077 9th May 2016 10:32am
scotty38
Thanks both, I particularly mentioned the short run but didn't say that I had 2 further stops and starts on the way back, so in say 20 miles it was stopped and started three times of its own accord with no bother.
Unless the battery was just borderline to start with then I was confused how it appeared to be ok subsequently.
If it had been just borderline to start with would I'd have expected to get the car turning over even if only slowly.
Would that not be the case and does this give you any more to go on with?
Just to add, I will check the earth but it stopped working suddenly and just as quickly became well again, wouldn't I expect a few more intermittent issues if it was loose(ish)?
Post #530082 9th May 2016 10:52am
Depends on how rough the roads are, whether it's tighter or looser etc.
Variable.
The earth clamp isn't the best design.
Post #530109 9th May 2016 12:08pm
Mjibex
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
Charge the battery with a decent charger and you will know the state of play; as you start the charging process.
A warm engine will turn over far more easily than a cold engine! Plus won't demand glow plugs.
Driving for a short period will not fully charge the battery.
Post #530180 9th May 2016 5:27pm
scotty38
Thanks again and will do all these things but just for info I tried it this evening, so it had not been started since Saturday morning, and it fired up first time just like normal...
Post #530200 9th May 2016 6:09pm
Happyoldgit
Wiggle to re-seat the relays in the seatbox under the drivers seat Steve.
http://forums.lr4x4.com
Post #530358 10th May 2016 11:24am
Nevillerover
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Sumatra Black
disconnect battery, clean connections, check earths and then clean cable connections on solenoid, fully charge battery, reconnect battery.
Post #530368 10th May 2016 12:15pm
Waldo
Could it be the contacts in the starter which have worn away?
From memory I had very similar problem on my TD5 and this was the issue,
That was in 2012, and it's an 03 vehicle
Bought one of these and fitted it with no problems since on that front.
http://www.ebay.co.uk/itm/DISCOVERY-DEFEND...aLg6A8kzew Defender 90 XS TD5 (03 Reg)
Post #530951 12th May 2016 10:44am
scotty38
Thanks again all, going to have another look over the weekend but as I say other than the one glitch it's worked absolutely fine since....
Post #530957 12th May 2016 10:56am
Waldo
Well at least you've got the answers prepared in advanced should it re-occur Very Happy Defender 90 XS TD5 (03 Reg)
Post #530963 12th May 2016 11:18am
spudfan
Ireland
If you buy a battery booster and connect it to the battery when you start the vehicle the vehicle battery will not be doing all of the work and it will help prolong battery life in a vehicle that is used irregularly and then for short journeys. It won't take your battery as long to recharge after starting the vehicle.
I have a 110 tdi in storage and always connect a battery booster to it when I start it up and it has helped the battery to keep going. Just remember to recharge the booster pack after you use it. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #531159 12th May 2016 10:32pm
Mattyboy
United Kingdom 2007 Defender 90 Puma 2.4 HT Santorini Black
I've had a similar problem today where my Land Rover 2.4 will not start yet the battery is fully charged and the battery leads are tight. It started fine after a push start, so I know it's not an alarm fault. When you turn the key you just get a clicking sound. I hope to God it doesn't need a starter as that looks a pig of a job 07 Defender 90 TDCI
98 Defender 90 300 Tdi
Land Rover Freelander
MG B GT
CBR 600
AEC Matador
but no washing machine
Post #533482 21st May 2016 6:44pm
scotty38
I've not found anything obviously wrong with mine and it's been fine since......
Post #533824 22nd May 2016 8:27pm
