Home > Wheels & Tyres > Mickey Thompson ATZ tyre pressure's
TC
Have just emailed Mickey Thompson asking for tyre pressure recommendations based on axle weights and gross vehicle weight for each type of use. Tyres are 305/60/18's.
Will post up response if and when I get it.
TC
Post #46991 1st Dec 2010 9:00pm
TC
Rapid response received!
The recommendation is for between 45-50 psi front and rear for mixed use Shocked
I emailed back and asked to clarify and the response was reconfirmed.
Now the book says 28 front and 48 rear for a TD5 110 so the rears would be within that but the fronts way over. What are peoples views?
Cheers,
Steve
Post #46999 1st Dec 2010 9:36pm
fekete
The bigger the tyre the less psi.... your only running 60s so you would need more psi than 28 in your fronts Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #47003 1st Dec 2010 9:57pm
TC
Will go for 35 front and 45 rear and see where that gets me........he did recommend to keep an eye on wear.
Post #47004 1st Dec 2010 10:07pm
discocuzzy
Run mine at 32 all round, mine are 16s though You cannot teach stupid people to do clever things
Post #47011 1st Dec 2010 10:32pm
