Home > Wheels & Tyres > Mickey Thompson ATZ tyre pressure's |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 |
Rapid response received!
The recommendation is for between 45-50 psi front and rear for mixed use I emailed back and asked to clarify and the response was reconfirmed. Now the book says 28 front and 48 rear for a TD5 110 so the rears would be within that but the fronts way over. What are peoples views? Cheers, Steve |
1st Dec 2010 8:36pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
The bigger the tyre the less psi.... your only running 60s so you would need more psi than 28 in your fronts NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
1st Dec 2010 8:57pm |
Will go for 35 front and 45 rear and see where that gets me........he did recommend to keep an eye on wear. |
1st Dec 2010 9:07pm |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 |
Run mine at 32 all round, mine are 16s though You cannot teach stupid people to do clever things
1st Dec 2010 9:32pm |
