Home > Technical > PTO for TDCI
Page 2 of 2 <12
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Arr I see now. That’s a great help. Thanks.
Post #811125 20th Jan 2020 9:38am
tacr2man wrote:
There are two take off points for pto on a LT230 transfer box, in the back and underneath , you can then either fit a prop type mech takeoff or a hyd pump . the undernaeth option is a lot more expensive than the rear , due extra castings etc,
I am happy to be corrected and told that someone has done this, but I don't think the bottom PTO can be fitted to a TDCi due to the lack of clearance for the exhaust. I suppose that it might be possible to create a custom exhaust that fits, but with the standard system there is simply not enough room for the PTO. There should be no particular problem fitting the standard rear PTO.
Post #811127 20th Jan 2020 9:39am
Page 2 of 2 <12
