Home > Puma (Tdci) > clunking sound when pulling up
dasha
Australia 2010 Defender 110 Puma 2.4 SW Stornoway Grey
when rolling to a stop and the car in neutral there is a clunking noise and also you can feel a slight shudder thru the gear box( i think) Question . it doesn,t happen all of the thime and as the car is getting more k,s on it 10k it is getting less frequent. any ideas ?? series 3 swb gone . o5 defender gone
Post #46705 30th Nov 2010 8:03am
Andrea
Dasha
Dasha, Best thing to do in this case is take it to your dealership and let them put the "earmuffs" on and let the warrenty work its wonders. Mine did a similar thing, turned out to be something small with the rear diff. They replaced the unit with a new one-no problems. Razz
Post #46707 30th Nov 2010 8:19am
dasha
Thanks Andrea went that route, bloody thing didn;t do it, well not as loud or long as normal so the mechanic couldn;t pin point it series 3 swb gone . o5 defender gone
Post #46708 30th Nov 2010 8:24am
MK
Mine that sympthom, but in the back. I was one bush from the A-frame. Did you check the UJs? Puma 110" SW
Post #46711 30th Nov 2010 8:49am
alantd
Mine did that - especially when warmed up.
The dealer adjusted the parking brake and that solved it....
... for a while. Started doing it again now.
I'll have them adjust it again but next year I'll stick an X-eng disc brake on it instead of the heavy drum lump (I can't believe how much metal gets spun up!) One that started out as a 2.4 TDCi 110 XS
Post #46913 1st Dec 2010 12:12pm
Merlin
Mine did that, turned out to be the UJ on the rear propshaft. Should that go in only 2 1/2 years of use?
Merlin.
Post #46920 1st Dec 2010 12:47pm
TRR Motorsport
United Kingdom 2010 Defender 90 Puma 2.4 ST Galway Green
Re: clunking sound when pulling up
Yeah, mines done that since the day it drove off the forecourt. Sounds like back lash on front diff to me but will take it in to a dealer when i can find local dealer with a decent service department (if there is such a thing). "If it ain't sideways, you just ain't tryin'!
Post #46922 1st Dec 2010 12:55pm
Grockle
Ribblesdale in Settle and Kendale in Kendal,both top Defender dealers,pity they are so far away for some of us 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #47045 2nd Dec 2010 11:06am
