Home > Puma (Tdci) > Annoying squeak - possibly steering column? |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 |
Does it do it more when your going over bumps? Mine does it every now and again and it turned out the be the seat base.
29th Nov 2010 9:51pm |
LCJ Member Since: 07 Sep 2009 Location: UK Posts: 201 |
Hmm not noticeably more, but as that's an easy fix I'll start there in the morning
29th Nov 2010 10:02pm |
rick Member Since: 07 Mar 2008 Location: Perth Posts: 133 |
My mystery squeak turned out to be the drivers side very back seat (7 seater) - strange, the squeaks sounded much closer, I could swear they were coming from the front (sounds really do carry far in a Defender).
Cheers, Rick. 1998 RR HSE 2007 RRS TDV6 2008 Defender 110 2015 Discovery Sport |
30th Nov 2010 5:58am |
Thanks, will check that too.
Bigger priority right now though is the rear windscreen, which shattered while out in the snow this afternoon |
30th Nov 2010 6:03pm |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 |
I thought i had a dashboard squeak but it turned out to be the bolt in the corner of the roof(front left) coming loose. At least i can fix the leaks while the headlining is out. 130 crew cab
98 V8 Disco |
30th Nov 2010 6:45pm |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 |
I had a similar mystery squeak, it turned out to be the passenger side rear seat. It was coming from somewhere in the hinge mechanism.
It took ages to find however, because it appeared to be coming from all over the place. I needed the help of the missus to find it. Funny acoustics in these Defenders. |
1st Dec 2010 5:58pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
I was very proud when mine started squeaking - finally a REAL defender
Exactly as you described (in fact I have 2). They sound like they're coming from the front because the sound bounces off the windscreen in front of you. I've got cargo barriers, window guards, tool boxes... in the back so I've given up trying to find it One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
2nd Dec 2010 10:15pm |
4wheeler Member Since: 13 Apr 2010 Location: Melbourne Posts: 87 |
I think others might have mentioned this in other posts but on some vehicles the OBD II (on board diagnostics) connector port below the steering column dash section above the pedals (under the cover) can rattle/squeek as the securing bolt loosens with time. Mine did this on my 07 Defender. I found it when I fitted up a ScanGauge II unit to the port. Since then the rattle has ceased. Worth checking just in case.
3rd Dec 2010 4:27am |
Thanks all, seems like I'm looking for a needle in a haystack of squeaking needles, but when it warms up I'll get started.
In the meantime I'm still waiting for a new rear windscreen from Landrover. They reckon they cant get through the snow and I wont have one until Tuesday! I found that irritating, cold, but slightly ironic |
3rd Dec 2010 10:43am |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4729 |
You can get a squeak coming from the dashboard area when your higes get very dry. Squirk some WD40 or similar stuff on the hinge rubbers where they swivel. That should sort one of your squeaks. 1982 88" 2.25 diesel
3rd Dec 2010 11:13am |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
Ref: OBD connector squeak/rattle. On my 2010 it is just a push fit into a holder. Found out when I fitted a Scangauge. Flap cannot close with connector plugged in so pushed the OBD connector out and took it behind the speaker where there is a big space to accommodate the OBD connector with the Scangauge connector plugged in.
3rd Dec 2010 3:23pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
My TD5 sqeaked in hot weather when the trim on the steering wheel expanded enough to rub slightly on the binnacle trim. Cured by silicone grease.
3rd Dec 2010 3:42pm |
nikojo Member Since: 05 Aug 2011 Location: Madrid Posts: 75 |
I had a very similar "squeek"......like a mouse. Took the whole dash apart and NOTHING.
It was the bonnet hinge where the plastic insert is!!!!!!!!! A little silicone grease and it's GONE. Was driving me nuts for weeks.........became obsessed with it. |
23rd Sep 2011 4:38pm |
John110 Member Since: 20 Nov 2011 Location: Co. Meath Posts: 106 |
I've another very annoying squeak coming from the 2 front doors (2003 110 Crew cab)It's driving me nuts, especially now that I have sound deadening and disco gears fitted. I'm fitting 2011 bottom door seals tomorrow, any other ideas? Yet again thanks in advance for any help
Cheers John For those who understand, no explanation is needed... For those who do not understand, no explanation is possible |
28th Dec 2011 10:02pm |
