Home > Puma (Tdci) > Electric cooling fan
Page 2 of 2 <12
Okan
Switzerland 2009 Defender 110 Puma 2.4 SW Stornoway Grey
Hi
I can tell you because I'm doing it on my 2.4 PUMA.
You CANNOT change your thermostat without remove the FAN. Why? Because to remove your thermostat you have to acces to it. And to access the thermosat you need to remove the fan shround and you cannot remove the fan shroud without removing the fan.
Do do like me, I brokent my fan shroud trying to remove it with the fan in place. So I ordered the appropriate tool to remove the fan. Expensive but the best way. And it will be usable again.
I don't know how it is on the 2.2 but I think it's similar to the 2.4
best regards
Post #582081 2nd Dec 2016 9:10am
Beery
Australia 2015 Defender 130 Puma 2.2 HCPU Corris Grey
I replaced the thermostat on my 2.2 with the fan and lower shroud still in place. Tight, but doable
Post #582120 2nd Dec 2016 11:12am
smb
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
^^^Likewise, it was a bit of a b.tch to do and I ended up with sore knuckles and scratched arms, but I did it without moving the bottom shroud and fan on my 2.4.
Post #582176 2nd Dec 2016 2:05pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Remote Hose Clip Pliers make it much easier!
Post #582180 2nd Dec 2016 2:24pm
smb
I only learnt about those after I had finished my box of elastoplast!!!
Post #582184 2nd Dec 2016 2:52pm
Page 2 of 2 <12
