Home > Off Topic > Fitting a landline to garden office
Page 2 of 3 <123>
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
yes its in use for networking to another TV and separate router in the loft only to expand the wifi range but that's another story!
Post #525944 22nd Apr 2016 1:51pm
excossack
Could you run a power line adapter for the CAT 5 (Data) from the house to the shed/office and then the CAT5 that was used for the data re-patch/re-wire for voice? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #525945 22nd Apr 2016 1:57pm
Snowy90
Hi excossack,
from my router to the office I can run any number of cables that's fine but my issue is under my floor I only have 1 CAT5 cable which is in network use.
My telephone point is at the front of the house and my router at the back.
Post #525946 22nd Apr 2016 2:01pm
Snowy90
been looking at the vonage systems and that looks interesting as well but I would either have the vonage box at the front of the house, same as I do at the moment.
Or need to get a telephone signal to the back of the house/garage
im thinking its trying to get another cable from the front of the house to the office is my only solution.
Anyone use vonage looks interesting and ultimately cheaper than VM
Post #525947 22nd Apr 2016 2:11pm
Rashers
I'm not sure if this would work, but if you have a decent mobile signal, and your contracts on both landline and mobile don't make it cost prohibitive, forward your landline to your mobile may be a quick fix.
Post #525948 22nd Apr 2016 2:11pm
Snowy90
Rashers interesting!
I tend to use my mobile more than my land line mainly because its so rubbish. MObile signal is fine
I will look into that.
Post #525949 22nd Apr 2016 2:12pm
excossack
Snowy90 wrote:
Hi excossack,
I assume the one CAT5 cable running from house to the office is fed from the router in the house ?
If so I was thinking more along the lines of a power line adapter(power line adapter to take data over the mains cable) in the house and plug in the CAT 5 cable from the house router into the power line adapter. In the office end another power line adapter and CAT 5 from power line adapter to the office router.
This should free up the single existing CAT 5 from house to office to be used for a phone line? 1999 Defender TD5 110
Regards
John M0VAZ
Post #525952 22nd Apr 2016 2:23pm
Snowy90
Now that's interesting, off I go to google that!
Post #525955 22nd Apr 2016 2:27pm
Martin
Site Admin
You still have the problem of getting phone to behind the TV.
And in my experience the Powerline adapters are not reliable when used to try and bridge to an outbuilding.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #525961 22nd Apr 2016 2:42pm
Snowy90
I think the powerline adapter might just be the way forward to free up the CAT5 under the floor for use as the land line. then I can join it to the office.
Post #525967 22nd Apr 2016 2:52pm
Snowy90
So lets rehearse this.
my internet is fed to the superhub behind the TV. I use a powerline adapter from the superhub and the other end in the front room where the CAt5 cable under the floor comes out which I understand will mean that my in house network is ok.
This means the CAT5 under the floor is now surplus?
I can then use the surplus CAT 5 as the phone line from front to back of the house where I can join it to a standard phone line?
I can then run a standard phone line to the office down the bottom of the garden.
Does this sound like a plan?
Post #525969 22nd Apr 2016 2:59pm
VeeTee
Netherlands
If your BT Elements phone is Dect, then you could use a dect extender like the DistyBox.
It connects wireless to your dect base station in the house, then you connect a wired phone to the extender. Cheers, Vincent
MySite
Post #525981 22nd Apr 2016 3:21pm
Snowy90
I tried a repeater before, an RTX one but I have to say it didn't really help, I think a big problem with my office is that's its insulated with celotex and the foil lining has made my own faraday cage so signal struggles to get in.
A wired approach would be the best I feel.
Post #525985 22nd Apr 2016 3:31pm
excossack
I was thinking more like:
Superhub CAT 5 cable > Powerline adapter behind TV into a mains plug
Powerline adapter in the office CAT 5 cable into the router.
Then you would free up the CAT 5 cable from house to office to reuse as a telephone line extension 1999 Defender TD5 110
Regards
John M0VAZ
Post #526035 22nd Apr 2016 6:13pm
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
Sorry if I have missed something, can you not run a new phone cable from your main phone socket to your required position?
Post #526052 22nd Apr 2016 7:09pm
Page 2 of 3 <123>
