![]() | Home > Td5 > oil in the ecu |
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 ![]() ![]() ![]() |
Yes.
Oil will continue to drain through the main harness into the ECU for a short while, but it will only become a problem when it reaches the multiplug. Don't pay 1400 euros for a 30 euro part and an hour with a spanner and some solvent cleaner.... This is for a Disco but the oily bits are the same for the defender; http://forums.lr4x4.com/index.php?showtopic=42788 My blog - www.anacreinhampshire.blogspot.co.uk 110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17715 ![]() ![]() ![]() |
This subject was comprehensively discussed very recently in this thread:-
http://www.defender2.net/forum/topic4426.html One thing to note is that the oil leaks down the insides of the conductors and it will keep doing it unless you seal the connector in the new injector harness. |
toshers Member Since: 19 Sep 2010 Location: Inverurie Posts: 120 ![]() ![]() ![]() |
I've seen oil contamination inside the ECU box too. It might be worth opening that up to check while you're there.
slevani Member Since: 21 Nov 2010 Location: ireland Posts: 3 ![]() |
Thanks for the advice and the links. I am going to change the injector harness only and not the engine harmess. Apparently there was oil in the
ecu according to the mechanic (I thought opening the ecu is not a good idea). I will let you know how it goes |
You can open de ecu, but the top is tin and glued to the base.
I changed the both the looms as I didn't have to pay for the looms. ![]() In your case I would change the injector loom and open the ecu. (if it is already broken you can't damage much) ![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Thanks for your help, my td5 is running better than before. Sorry for the delay on getting back but I was out of town for couple of weeks. When i clean the connector will I need to disconnect the battery.
