Home > Td5 > oil in the ecu
slevani
oil in the ecu
My td5 defender broke down in france. The problem is oil in the ecu. I was given a quote of 1,400 euros to fix. The largest part of the cost is due tto the engine harness ( 585 euro as it is landrover genuine part). + labour. The injector harness is less expensive and easier to replace. My question... can I get away with just changing the injector harness and just clean the engine harness (loom). Thank in advance !!
Post #45986 22nd Nov 2010 9:45pm
SiWhite
United Kingdom 2013 Defender 110 Puma 2.4 USW Stornoway Grey
Yes.
Oil will continue to drain through the main harness into the ECU for a short while, but it will only become a problem when it reaches the multiplug.
Don't pay 1400 euros for a 30 euro part and an hour with a spanner and some solvent cleaner....
This is for a Disco but the oily bits are the same for the defender;
http://forums.lr4x4.com/index.php?showtopic=42788 My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold!
110 Tdci Build HERE - sold!
Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender!
Post #45994 22nd Nov 2010 11:11pm
This subject was comprehensively discussed very recently in this thread:-
http://www.defender2.net/forum/topic4426.html
One thing to note is that the oil leaks down the insides of the conductors and it will keep doing it unless you seal the connector in the new injector harness.
Post #46000 22nd Nov 2010 11:58pm
toshers
Scotland 2011 Defender 110 Puma 2.4 USW Orkney Grey
I've seen oil contamination inside the ECU box too. It might be worth opening that up to check while you're there.
Post #46045 23rd Nov 2010 5:22pm
slevani
Thanks for the advice and the links. I am going to change the injector harness only and not the engine harmess. Apparently there was oil in the
ecu according to the mechanic (I thought opening the ecu is not a good idea). I will let you know how it goes
Post #46054 23rd Nov 2010 6:40pm
roel
You can open de ecu, but the top is tin and glued to the base.
I changed the both the looms as I didn't have to pay for the looms. Whistle But it is some work to change them but it is not difficult.
In your case I would change the injector loom and open the ecu. (if it is already broken you can't damage much) Whistle See if there is any oil in it and if so clean it. Clean the other connectors and see if it will be running fine. Roel
2003 90 Td5 (2009-now)
Post #46399 26th Nov 2010 3:29pm
slevani
Thanks for your help, my td5 is running better than before. Sorry for the delay on getting back but I was out of town for couple of weeks. When i clean the connector will I need to disconnect the battery.
Post #48914 18th Dec 2010 10:26am
