![]() | Home > For Sale & Wanted > [Wanted] 36 spline Type C Steering Wheel leather |
Vince VDB Member Since: 17 Nov 2014 Location: Champagne sur Oise Posts: 60 ![]() ![]() ![]() |
Difficult to find !
What do you think about this : buy a 48 spline, take off the leather, and put it on a standard type C 36 spline ? With or wjthout leather, are steering wheels the same ? Defender 110 Puma 2.4 SW SE Defender 90 300 Tdi SW with TD5 body Land 90 V8 HT |
It probably easier to buy a 48 spline column and swap it over
![]() My build thread http://www.defender2.net/forum/topic17615.html |
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 ![]() ![]() ![]() |
Is that possible?
Never tried it but don't see why not, Landrover fitted 36 and 48 spline columns to the same vehicle years so should just be a bolt in job. Ray
Wonder if it wold work with a range rover steering wheel?
I think range rover classic steering wheels are 36 spline so should go straight on but I don't know what the indicator cancelling bits look like or if they will work. Ray
Lotus_esprit_s1 Member Since: 01 Oct 2014 Location: Uk Posts: 201 ![]() |
Yes, the column is a straight swap but a bit involved as you have to partially strip the dash.
I was going to do this to my parents 56 plate County spec 90csw, it had the 36 spline "c type" wheel but not leather which he wanted. Couldn't find a 36 spline leather one for love nor money, none were on eBay for months on end so decided to swap the columns. In anticipation, I purchased a 48 spline leather wheel off eBay. Amazingly, when it turned up, it was actually a wrongly listed 36 spline! |
