Home > Camping, Caravanning and Holidays > Painting a sankey do I Red oxside first?
Stacey007
Hello
Given I have decided not to have the trailer sandblasted and painted professionally.. I'm doing it Smile The worse that can happen is that I do need to have it sand blasted etc afterwards...
Question, I've rubbed away all the flakey paint. Do I need to paint the whole thing in red oxide (or other primer) before a top coat?
I've been told to roller the paint on also for best finish.
Top coat I was thinking Hammerite smooth black (as my cars black) but would another other option be better as I've also heard this is hard to get a neat finish as it dry's quickly and also satin may give a better finish.
What have other people done with theirs?
I'm happy to just roller the inside of the tub with hammerite as I will probably try and cover this with rubber matting also but for the outside of the tub I would like it to look reasonable. Smile
Thanks
Post #518866 29th Mar 2016 2:52pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
I wouldn't use Hammerite, its awful stuff, drys too quickly and once dry and hard it chips off easily. I would use a normal brushing enamel from say The Paintman which you can use a roller to apply. As long as the existing paint is sound and well adhered to the steel, I would just flat it down and apply some primer to any bare steel.
Post #518889 29th Mar 2016 4:06pm
muddybaldboy
Wales 1999 Defender 110 Td5 HT Chawton White
Inside and out with Raptor lining.
I'll gladly bring the gear over and help. Just cover bare metal with upol etch primer then blast it on Thumbs Up He who dies with the most toys...wins!
Post #518969 29th Mar 2016 6:45pm
THF
United Kingdom 2004 Defender 110 Td5 XS CSW Oslo Blue
Stacey007,
I got a VGC Mk3 trailer off FleaBay; when living down Plymouth way I took it to a local sand-blaster, (he usually did yacht hulls so fairly gentle). He cleaned the MOD green back to provide a decent key, then Red Oxided it for me. Then I sourced some Chassis Black ( http://www.frost.co.uk/frost-chassis-black-paint.html ) and took it to a local body shop who thoroughly covered it it Chassic Black. I managed to ge this to do the job out of one tin, and pretty much got every nook & cranny. While this was going on I took the tub and got it sprayed to match my 110; all in all it looks pretty dam good. Once I dig some phots off my old mac I'll add them to the post.
Can't recommend it enough, that was 2 yrs ago, its stored outside under the original cover (& a little bit of tarp) and it still looks as good!! Very Happy
Hope it helps!
THF
Post #519070 29th Mar 2016 9:06pm
Stacey007
^ Some pictures would be great.
I'm not planning on getting it sand blasted and professionally sprayed though, decided to try to do it myself..
It will live in a garage so I'm lucky in that respect.
Post #519074 29th Mar 2016 9:21pm
LR90XS2011
spraying yourself in a garage can get great results but ditto from me dont use hammerite it is great on small cast parts but not great on big smooth areas. I would use paints that are suitable for spraying including the primer they are not that much more expensive and the results justify them. DEFENDER 90 TDCI XS,
Post #519129 30th Mar 2016 7:21am
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
No need for red oxide, just any primer will suffice, and a top coat/lacquer that is compatible together.
Speak to a local bodyshop supplier and they will helpful and knowledgeable. These guys could be local to you http://www.colourtone.com/
I used hammerite on the chassis of mine and as others have mentioned it dries way to quick to try applying it with a roller, and the outside of the tub painted by a friend of a friend in his garage for roughly £50 IIRC including materials and a drink.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #519209 30th Mar 2016 12:16pm
Probably Epoxy primer would be most suitable.
If it was Alu which it isn't I don't think? Then Etch.
Thumbs Up
Post #519211 30th Mar 2016 12:23pm
X4SKP
Hello Stacy007
I used Smooth Black Hammerite on top of Hammerites Special Metals Primer
(Aluminium Floor and Body Panels on a Rapier Trailer) All paint was applied with a roller.
Hammerite is the Marmite of Paints for some, but the formula now used changed a few years back and IMO
isn't the unforgiving product it once was. I obtained all the paint used free issue from a supplier to our business
so this did influenced the decision to use it, results are good enough and can be 'refreshed' as needed depending
on how hard a life the trailer has.
Good Luck... SKIP
Post #519214 30th Mar 2016 12:40pm
Stacey007
Hello
Thanks all, Did you people who have done this sand back right to bare metal everywhere?
Or as I have done remove the rusty bits and sand down the flakey paint then prime?
Such as this below, partly sanded to bear metal can I prime this whole panel and then top coat? Removing the Nato paint is a pain in the.... and too be honest the majority of it is fine I just want to change the colour...
Thanks all
Post #519229 30th Mar 2016 2:03pm
X4SKP
Hi Stacy007
If it's stuck...leave it stuck, just key the surface, and use an etch primer or special metals primer.
The primer is the 'key' here (sorry), any good paint isn't cheap, so surface preparation prior to the
top coat is worth it...also choose a warm dry day(s), mine took a weekend to paint when prepared... Shocked SKIP
Post #519236 30th Mar 2016 2:43pm
THF
Stacey,
As promised:
Red oxide post fine sand blasting and sprayed on (Appreciate you intend to brush).
The I got it sprayed with Frost's Chassis Black.
It leaves a fairly robust finish that retains its shine.
I then got the tub painted Oslo Blue and wax oiled the base:
Hope it helps you with your plans
Jack.
Post #521043 5th Apr 2016 7:29am
Stacey007
^ Looking great,
Have you a picture with the sprayed chassis and new top together,
Sent a PM Smile
Post #521053 5th Apr 2016 8:19am
