Home > Maintenance & Modifications > Anderson Connectors
Page 2 of 2 <12
leeds
We recommend 35mm2 COPPER cable for jump leads and battery connections.
We see all sorts of cable and crocodile clips sold. Some of the claims are just Rolling with laughter Rolling with laughter Rolling with laughter
Eduardo, if you want some Anderson connectors posting to Chile give us a shout, drop me a pm
Brendan
Post #111802 3rd Jan 2012 8:18pm
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
thank you Brendan ! www.newfoundland.gr
Post #111813 3rd Jan 2012 8:42pm
Eduardo
Brendan
Thanks leeds Thumbs Up Eduardo
Post #111846 3rd Jan 2012 9:56pm
Tazz
So if I wanted to buy a pair of 5m battery jump leads fitted with a 175a anderson connector, along with a pair of short leads also with a connector to wire to the battery - where would I go and how much can I expect to pay?
I've tried the site's sponsors but nothing listed on their web sites and looking at ebay it's difficult to tell genuine connectors from poor imitations.
Post #115320 14th Jan 2012 2:12pm
leeds
Hi Tazz, drop me a pm stating exactly what lengths you want, also your post code.
Anderson connector to battery, what crimp terminals you require, standard crimp tube terminal hole for battery clamp is 8mm.
What length cable from Anderson connector to crocodile clip.
Crocodile clips we use are fully insulated and have a connecting braid between them and are rated at 300 amps continuous
Choice of cable is 35mm2 single core at £6/metre/colour. IIRC this is rated at 240 amps continuous
Or 35mm2 twin flex cable. Both cables joined together so form a neater package, basically a tidier way of keeping jump leads. Down side of twin flex is that the continuous current rating is down graded to about 180 amps and cost of twinflex is £14/metre
Brendan
Post #115331 14th Jan 2012 3:24pm
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
I got my connectors Thumbs Up from Brendan, i think he also does a kit or may make them up for you. 130 crew cab
98 V8 Disco
Post #115333 14th Jan 2012 3:25pm
Page 2 of 2 <12
