![]() | Home > Maintenance & Modifications > Anderson Connectors |
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 ![]() ![]() ![]() |
thank you Brendan ! www.newfoundland.gr
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 ![]() ![]() ![]() |
Thanks leeds ![]() MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Tazz Member Since: 24 Mar 2011 Location: Harrow Posts: 90 ![]() ![]() |
So if I wanted to buy a pair of 5m battery jump leads fitted with a 175a anderson connector, along with a pair of short leads also with a connector to wire to the battery - where would I go and how much can I expect to pay?
I've tried the site's sponsors but nothing listed on their web sites and looking at ebay it's difficult to tell genuine connectors from poor imitations. |
Hi Tazz, drop me a pm stating exactly what lengths you want, also your post code.
Anderson connector to battery, what crimp terminals you require, standard crimp tube terminal hole for battery clamp is 8mm. What length cable from Anderson connector to crocodile clip. Crocodile clips we use are fully insulated and have a connecting braid between them and are rated at 300 amps continuous Choice of cable is 35mm2 single core at £6/metre/colour. IIRC this is rated at 240 amps continuous Or 35mm2 twin flex cable. Both cables joined together so form a neater package, basically a tidier way of keeping jump leads. Down side of twin flex is that the continuous current rating is down graded to about 180 amps and cost of twinflex is £14/metre Brendan |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 ![]() ![]() ![]() |
I got my connectors
![]() 98 V8 Disco |
