![]() | Home > Tdi > 300TDI getting warm too easily.... |
The best bet would be remove the thermostat and run like that a few times to see if that is a problem, failing that there is a thin pipe that comes off the header tank, it runs to the thermostat housing and the radiator, I have seen overheating problems when this is blocked. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
So how hot is it actually getting? 100degC is perfectly normal.
Craig Jones Member Since: 06 Mar 2016 Location: Bristol Posts: 3 ![]() ![]() ![]() |
I can get her to 100c on a long climb, but I thought they should run at 90, and always try to keep under 100?
Assuming I have that wrong, what's the max, ideal etc? |
MuddyChris300tdi Member Since: 02 Mar 2014 Location: Derby Posts: 224 ![]() ![]() ![]() |
I'm just looking into why mine seems to be running hot. On a run mine sits just under the red.
![]() Click image to enlarge I'm going to try a new sensor and then take the stat out. Then I think it will have to be a new rad. |
Never seen a gauge like that before. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
Tompoole Member Since: 05 Jun 2011 Location: Bucks Posts: 828 ![]() ![]() ![]() |
If it's a tdi it will need a stat in it so you'll need to jam it open as opposed to
Running without one Have fun be happy |
I have run a few 300tdis without thermostats in various countries as the need has arisen. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
mine runs at 72deg when warm, on a hot day that can climb to 76deg. that is actual head temp though not water temp! i have no idea what the water temp is!! My 109 thread
my youtube channel |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 ![]() ![]() ![]() |
with a water temp like that you must have one of only a few 200/300's with a warm heater! 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 490 ![]() ![]() ![]() |
Mine runs mid scale and is roasting, just needs adjusting properly, found a few others like that as well 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
Well I did an 8 mile drive today at mixed speeds and the needle sat bang on 90c. When I stopped I checked the top and bottom rad hoses. There both hot i can touch them for about 5 seconds the bottom hose that goes to the header tank is stone cold. I'm leaning towards it needing a new rad. And the heater is red hot. Doesn't help that the adjuster needs adjusting. It's either hot or cold.
You've lost me. 88-90degC is exactly where you want it to be running. Overcooling is not good for an engine you certainly don't want it running any cooler than 82degC.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20627 ![]() ![]() |
IIRC 88C is the benchmark usually.
I've noticed on mine since coolant change a slight drop in running temp which is good, but only a tiny drop. But mine is a 2.4, I assume they should all be similar though. |
My previous post showed gauge just in the red, and it will sit there on a go run. Today was a short run at lowish speeds. It was more finding that the bottom hose was as hot as the top hose. I expected a noticeable difference between the two.
