Home > Td5 > Tuning data file |
RichardL Member Since: 24 Mar 2016 Location: Costa Rica Posts: 5 |
I am using Map svl0r005-svtnp006.
2002 Defender 110 TD5 2.5 Having injector problems so I found some good used ones; installed them changed the injector setting in the map and it will not fire I get no smoke at all from the tail pipe. I did run the purge over and over and over. Update; re-mapped used tune-data file from TD5 map editor! Now found air leaking into or thru new fuel pump; loosened rocker arm and hear air spewing from #3 and 4, fuel pump cycle on reach pressure and shut down in a couple of minutes repeat. Must pull tank and check factory hoses on new factory fuel pump. Maybe the end of this episode! Last edited by RichardL on 28th Mar 2016 1:54pm. Edited 1 time in total |
25th Mar 2016 12:48pm |
http://luca72.xoom.it/td5mapsuiteweb/downl..._win32.zip Roel
25th Mar 2016 6:42pm |
Thank you, used the file built tuning data file, saved to memory stick next to re-map. (First) next step.
Do you know of a entry by entry guide to the Lucas 10AS on board security system, so I do not immobilize, by mistake? My 110 does not have anything other than the dome light illumination when the door opens, Thank you Richard |
26th Mar 2016 1:07pm |
