Home > Td5 > Tuning data file
RichardL
Tuning data file
I am using Map svl0r005-svtnp006.
2002 Defender 110 TD5 2.5
Having injector problems so I found some good used ones; installed them changed the injector setting in the map and it will not fire I get no smoke at all from the tail pipe. I did run the purge over and over and over.
Update; re-mapped used tune-data file from TD5 map editor!
Now found air leaking into or thru new fuel pump; loosened rocker arm and hear air spewing from #3 and 4, fuel pump cycle on reach pressure and shut down in a couple of minutes repeat. Must pull tank and check factory hoses on new factory fuel pump.
Maybe the end of this episode!
Post #517664 25th Mar 2016 12:48pm
roel
http://luca72.xoom.it/td5mapsuiteweb/downl..._win32.zip Roel
2003 90 Td5 (2009-now)
Post #517748 25th Mar 2016 6:42pm
RichardL
Thank you, used the file built tuning data file, saved to memory stick next to re-map. (First) next step.
Do you know of a entry by entry guide to the Lucas 10AS on board security system, so I do not immobilize, by mistake?
My 110 does not have anything other than the dome light illumination when the door opens,
Thank you
Richard
Post #517925 26th Mar 2016 1:07pm
roel
If you change the map file it should not do anything with the as10.
The nanocom has a special part to play with the as10. Roel
Post #518185 27th Mar 2016 12:13pm
