Home > Td5 > Raptor Binnacle mounting |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 954 |
It really is fairly simple. I have helped others install the Raptor on their LR. I chose to istall the mud console. Lots of cutting of a the dash and fiddling about but very simple really. The raptor has less cutting and fiddlng in my experience. Should have instructions on their web site?
Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
16th Mar 2016 10:55pm |
Oops! You asked about the dash binnacle not the console, same applies actually, it is very simple. Four screws to remove the gauge cluster and unplug everything (two screws under the dash then one on each side). No need to label the plugs/wires as they all can only plug in one way. Disassembly installation and reassembly is straight forward nce you have it out.
17th Mar 2016 6:30am |
swisslandy Member Since: 16 Mar 2016 Location: Switzerland Posts: 3 |
Thank you for your answer. The binnacle itself is easy to unmount. I was just not sure about the mount behind the binnacle. As i found till now, the mount can be fixed when the heater and vent regulator unit is taken of as well. I d'dn't find any info on raptors website.
I 'll just give it a try. Andi |
17th Mar 2016 8:18am |
If you get stuck, take some pictures and post questions someone will have the answer for you.
Cheers 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
17th Mar 2016 11:32am |
perfect! I will. But first I'll have to work on my swivels.
Cheers! |
17th Mar 2016 2:41pm |
