Home > Td5 > Raptor Binnacle mounting
swisslandy
Hi there
this is my first post. I like to do some works on my Defender myself, but I am maybe a little to akward. Before starting I like to inform myself. I couldn't find any information in the german speaking Forums and on this forum on how to mount the raptor engineering binnacle mount to my td5 2002.
Does anybody have some pictures of the process?
Regards and thanks, Andi
Post #514980 16th Mar 2016 4:58pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
It really is fairly simple. I have helped others install the Raptor on their LR. I chose to istall the mud console. Lots of cutting of a the dash and fiddling about but very simple really. The raptor has less cutting and fiddlng in my experience. Should have instructions on their web site?
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #515154 16th Mar 2016 10:55pm
4RF RDS
Oops! You asked about the dash binnacle not the console, same applies actually, it is very simple. Four screws to remove the gauge cluster and unplug everything (two screws under the dash then one on each side). No need to label the plugs/wires as they all can only plug in one way. Disassembly installation and reassembly is straight forward nce you have it out.
1967 MGB GT
Post #515189 17th Mar 2016 6:30am
swisslandy
Thank you for your answer. The binnacle itself is easy to unmount. I was just not sure about the mount behind the binnacle. As i found till now, the mount can be fixed when the heater and vent regulator unit is taken of as well. I d'dn't find any info on raptors website.
I 'll just give it a try.
Andi
Post #515207 17th Mar 2016 8:18am
4RF RDS
If you get stuck, take some pictures and post questions someone will have the answer for you.
Cheers 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #515260 17th Mar 2016 11:32am
swisslandy
perfect! I will. But first I'll have to work on my swivels.
Cheers!
Post #515327 17th Mar 2016 2:41pm
