Home > Puma (Tdci) > Chequer Plate |
ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517 |
+1...black
16th Nov 2010 11:57pm |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 |
Silver You cannot teach stupid people to do clever things
17th Nov 2010 8:40am |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 |
Does anyone know if the LR supplied chequer plate comes with any kind of material to go between the wing tops and the plating? I can imagine that it might get a bit noisy/rattly depending on how the chequerplate is attached, no?
17th Nov 2010 8:54am |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
Couldn't you use Heavy Duty Velcro to secure and cushion the plates????
17th Nov 2010 9:10am |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
I have black on my stornoway grey truck. looks good. dont get the thin ones, they warp. mine came from paddock, 3mm. used rivnuts, cushined undernearth the plate with 1mm neoprene cut to just under the size of the plate |
17th Nov 2010 9:38am |
Yes they do. Similar / the same can be had from other places including http://mammouth4x4.co.uk/. There is quite a bit about the various manufacturers on the forum already. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
17th Nov 2010 10:08am |
johnnyturbo2002 Member Since: 21 May 2009 Location: Poniente Granadino Posts: 371 |
Does that mean if I remove my chequer plate, then ladies won't wear their undies? If so, I think I know what I am doing on my lunch break 2008 Defender 110 60 year Edition (sold unfortunately) IN the hunt for another Puma for the wifey! 2008 Kia Sorento LX 😁 2.5crdi |
17th Nov 2010 10:51am |
Simon S Member Since: 05 May 2010 Location: Bedfordshire Posts: 15 |
I went for genuine LR silver on my Stornoway Grey 110 (My main reason was that I thought black might scratch which would defeat the object?!?!??) PS Chequer plate seems to attract damage by people that think the car is totally scratch proof everywhere because of the plating on the wing tops and sills!!!!! Simon S 110 Utility |
28th Nov 2010 8:05pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
know what you mean.
even my wife says mine needs it for somehwere for tools, coffee etc. must admit i miss it. i shudder when i look a the LR prices though. i am actually getting worried about her.....she chose the Puma over the FL1 for a 100 mile round trip BM52 |
28th Nov 2010 8:16pm |
caribcat Member Since: 11 Jun 2009 Location: Anglesey Posts: 97 |
Thought of this using 3M 5200 sealant/adhesive but reckon it would simply lift the paint off! |
29th Nov 2010 4:12pm |
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 352 |
For those that have fitted the 3mm Mammouth using the supplied bolts and nylocs: How much work was it to get the inner wings out of the way?
Am I just best to go with Rivnuts? Thanks Keith |
12th Mar 2018 5:21pm |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 |
I went back and forth about fitting, don't particularly like it but as I had a roof tent at the time felt it was necessary.
Fitted 3mm with SS bolts and Nylocs. Fairly straight forward - took about 2 hours in total for both wings and bonnet. Make sure you have a step drill which will hep if drilling through bonnet strengthening braces. Been on car for the past 8 years and no sign of corrosion on chequer plate or wings. Click image to enlarge 2007 TD5 90 Hard Top |
12th Mar 2018 7:05pm |
