Home > Technical > Wolf 24v electrics
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Wolf 24v electrics
After owning several Defenders over the years , I have been looking at adverts for Wolf 90's to buy as use as a weekend toy.
Question for the experts, Is the 24v electric system a pain or are they very reliable? I understand certain items can be very expensive if they fail. I am mechanically minded but I leave fettling electrics to others so if the electrics go wrong I would be pretty lost.
Post #514122 14th Mar 2016 10:32am
jst
reliable in my experience, could always be changed to 12V easily Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #514123 14th Mar 2016 10:34am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Wolfs are really easily maintained, the electrics are the same as reliable as any other. As said it can be swapped to 12v if you want.
I shall send you a pm ref what they need to run. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #514167 14th Mar 2016 12:22pm
defender9
Thanks, jst and Mash. Thanks Mash would like to see what is needed for 12v.
Post #514231 14th Mar 2016 3:38pm
sib
Also if you end up towing a normal trailer with 12v electrics you can simply plug in a 24-12v converter to the existing trailer socket. Sib
Bath UK
1952 80 inch
1973 88 inch
2018 Morgan plus 4 narrow body
Post #514303 14th Mar 2016 7:14pm
