Home > Technical > Wolf 24v electrics |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8018 |
reliable in my experience, could always be changed to 12V easily Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
14th Mar 2016 10:34am |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
Wolfs are really easily maintained, the electrics are the same as reliable as any other. As said it can be swapped to 12v if you want.
I shall send you a pm ref what they need to run. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
14th Mar 2016 12:22pm |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 |
Thanks, jst and Mash. Thanks Mash would like to see what is needed for 12v.
14th Mar 2016 3:38pm |
sib Member Since: 18 May 2007 Location: Baaath Posts: 144 |
Also if you end up towing a normal trailer with 12v electrics you can simply plug in a 24-12v converter to the existing trailer socket. Sib
Bath UK 1952 80 inch 1973 88 inch 2018 Morgan plus 4 narrow body |
14th Mar 2016 7:14pm |
