![]() | Home > Tdi > 200TDi engine compression figures |
LRmud Member Since: 22 Oct 2014 Location: IV12 Highland Posts: 198 ![]() ![]() ![]() |
24 Bar (348psi) is what you're looking for but it's more a case of looking for the odd one out - which I think you've identified.
Head off! Best of luck LRmud -------------------------------------------------------------------------------------------------- 1989 Defender 90 Toyota Aygo & Honda FR-V |
Tony_Hillerby Member Since: 03 Feb 2008 Location: Inverurie Posts: 36 ![]() ![]() ![]() |
Thanks for that info
While we are doing it we will take a look and change the piston rings, do a bit of glaze busting and fit new rings and see if that also improves things. It will also let us see the state of the con rod bearings and change them as well. Haven't done an engine build for a while now, last one was a 3 litre V6 Essex engine for a series 3. Got it as a box of bits, put it together and it fired up and ran fine. Tony |
