Home > Tdi > 200TDi engine compression figures
Tony_Hillerby
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Santorini Black
Hi all
Does anyone know what the compression figures should be on a 200TDi engine. Took some figures and on cylinders 1-2-3 they were all the same about 320PSI and number 4 was 275. Its chuffing a bit so I suspect a head gasket on No 4 as its done it before many years ago. Its done 300K.
Tony
Post #513066 11th Mar 2016 1:07am
LRmud
Scotland 1989 Defender 90 300 Tdi HT Baltic Blue
24 Bar (348psi) is what you're looking for but it's more a case of looking for the odd one out - which I think you've identified.
Head off!
Best of luck
LRmud --------------------------------------------------------------------------------------------------
1989 Defender 90
Toyota Aygo & Honda FR-V
Post #513086 11th Mar 2016 7:44am
Tony_Hillerby
Thanks for that info
While we are doing it we will take a look and change the piston rings, do a bit of glaze busting and fit new rings and see if that also improves things. It will also let us see the state of the con rod bearings and change them as well.
Haven't done an engine build for a while now, last one was a 3 litre V6 Essex engine for a series 3. Got it as a box of bits, put it together and it fired up and ran fine.
Tony
Post #513749 13th Mar 2016 12:57am
