Home > In Car Electronics > Where can I find the reverse signal?
Spectre
Hi guys,
Looking at wiring up a nav unit with a reverse cam, I see there is a wire for a reverse signal.
Question is, where can I find this on the PUMA models?
Thanks for any help.
Post #511402 6th Mar 2016 6:22pm
andyace
United Kingdom 2010 Defender 90 Puma 2.4 HT Baltic Blue
You can run a wire from the reversing light, or dig deep into the gearbox for the signal.
Reverse light is less messy.
Andy
Post #514073 14th Mar 2016 8:18am
Spectre
Hi Andy
Yes that is the route I ended up taking.
I think the switch is somewhere on the gearbox on the PUMA models and a pain to locate.
Thanks for taking the time to reply to my post.
All the best.
Post #514174 14th Mar 2016 12:53pm
The switch is to the left and up of the main gear-lever.
In an awkward position and send awkward area to get at too.
Post #514179 14th Mar 2016 1:13pm
arno
Switzerland
You can find it on a cable on the fuse box under the seat, it's just after the switch on the gear box. I pick my signal just here for the reverse cam.
The cable is on a connector C0376-8 GN,1.0D,120 (green-Brown)
It's a grey connector with 24 cables on it, in the middle of the entrance of the 2 big chunk of wire.
[/img]
Post #518868 29th Mar 2016 3:03pm
Spectre
Helpful information, thanks for that!
Post #518925 29th Mar 2016 5:31pm
