Home > In Car Electronics > Where can I find the reverse signal? |
andyace Member Since: 10 Apr 2015 Location: dorset Posts: 5 |
You can run a wire from the reversing light, or dig deep into the gearbox for the signal.
Reverse light is less messy. Andy |
14th Mar 2016 8:18am |
Spectre Member Since: 26 Jan 2016 Location: South East Posts: 228 |
Hi Andy
Yes that is the route I ended up taking. I think the switch is somewhere on the gearbox on the PUMA models and a pain to locate. Thanks for taking the time to reply to my post. All the best. |
14th Mar 2016 12:53pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20563 |
The switch is to the left and up of the main gear-lever.
In an awkward position and send awkward area to get at too. |
14th Mar 2016 1:13pm |
arno Member Since: 24 Jul 2015 Location: Lausanne Posts: 31 |
You can find it on a cable on the fuse box under the seat, it's just after the switch on the gear box. I pick my signal just here for the reverse cam.
The cable is on a connector C0376-8 GN,1.0D,120 (green-Brown) It's a grey connector with 24 cables on it, in the middle of the entrance of the 2 big chunk of wire. Click image to enlarge [/img] |
29th Mar 2016 3:03pm |
Helpful information, thanks for that!
29th Mar 2016 5:31pm |
