Home > Puma (Tdci) > ABS Sensor
Beefmaster
South Africa 2008 Defender 110 Puma 2.4 SW Keswick Green
ABS Sensor
Hey guys,
Does anyone know where I can get a used but working ABS sensor for my rear left wheel?? Located this problem when searching for why my ABS and TC lights stay on...
Its a little difficult to find these in SA it seems... Confused
Post #45140 13th Nov 2010 11:53am
Merlin
I've got this problem. How did you isolate the corner with the problem?
Merlin
Post #45228 14th Nov 2010 3:08pm
Beefmaster
Hi Merlin,
By laying down in front of the front wheels you can see the ABS sensors quite easily, so you should be able to tell if there's one faulty there.. For the back wheels you need to look behind the wheel but on the front door side, to see the sensor. I immediately saw the faulty sensor just by looking at it, because it had been taped up loosely with some tape, real amateur job.. Anyway so I then removed the wheel and took the tape off and saw the damage on the wires there.. I assume this must be where the fault lies...
Now just to find a used but working sensor at a decent price!! Smile
Your ABS and TC lights also on?? Seems quite common Smile
Post #45229 14th Nov 2010 3:18pm
