Home > Puma (Tdci) > Ultra Gauge Paranoia? – Engine Temperature
Page 2 of 2 <12
Beery
Australia 2015 Defender 130 Puma 2.2 HCPU Corris Grey
You might want to try reducing the glycol concentration in your coolant from 50% down to 40% or 30%. This will increase the heat transfer capacity of your cooling system.
It will still give you antifreeze protection to about -20c.
Water is much more efficient at conducting heat than glycol.
Post #593967 17th Jan 2017 9:38pm
Eduardo
Thanks for the answers and in fact doesnt look very good.
The tank looks OK and no coolant leaking are visible but I will check again. I change almost all the coolant some month ago (after a pipe repair). I will see how much Glycol I have (I dont remember now) but for our use -20°C looks OK.
Cheers! Eduardo
Post #594078 18th Jan 2017 12:38pm
pannawonica
Australia
I have the usual cooling mods except the fan spacer! Heavy towing and grades still send the temperature too boiling point. Whilst being a pressurised system this is not such a problem. It does indicate that the cylinder head temperature sensor is pointing to a build up of heat. I think this is due too radiator efficiency, or lack of. I would like too hear from someone with an upgraded aftermarket radiator. Thumbs Up
Post #594632 20th Jan 2017 6:30am
Page 2 of 2 <12
