![]() | Home > Puma (Tdci) > Ultra Gauge Paranoia? – Engine Temperature |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Thanks for the answers and in fact doesnt look very good.
The tank looks OK and no coolant leaking are visible but I will check again. I change almost all the coolant some month ago (after a pipe repair). I will see how much Glycol I have (I dont remember now) but for our use -20°C looks OK. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 ![]() ![]() |
I have the usual cooling mods except the fan spacer! Heavy towing and grades still send the temperature too boiling point. Whilst being a pressurised system this is not such a problem. It does indicate that the cylinder head temperature sensor is pointing to a build up of heat. I think this is due too radiator efficiency, or lack of. I would like too hear from someone with an upgraded aftermarket radiator.
