Home > Technical > Main battery protectors
mse
Not really been looking for one for a while...but came across this:
http://www.noflatbatteries.com/index.htm fitted to some emergency vehciles.
Any comments Mike
Post #44815 9th Nov 2010 9:05pm
Presumably this will also make the alarm BBS go off when it activates.
Post #44836 9th Nov 2010 11:19pm
mse
Not if you apply a battery feed to the alarm on the main battery or use it to protect the second battery Mike
Post #44837 9th Nov 2010 11:24pm
BigMike
An Adveric split charge includes the ability to start from a second battery using a simple hold in switch mounted under the dash. A basic deep cycle leisure battery is about 60 quid, so on balance I would rather have that system as it offers you all kids of other possibilities, the ability to start using the second battery just one of them. In other words, for not much more money at all, you can have a second battery and split charge kit
Post #44846 10th Nov 2010 8:01am
mse
Sorry this kit isnt for that.
This kit stops you killing your batteries by leaving stuff on
eg in the bush running a fridge waking up and no juice
If you have two batteries you can always jump start from the other Thumbs Up to start assuming one has enough juice! Mike
Post #44890 10th Nov 2010 5:42pm
fekete
Great little device Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #44892 10th Nov 2010 5:56pm
BigMike
yeah i know. the point i was making is that for only a few quid more, you can have an easy split charge with a simple button that will flip the batteries over so you can start with the other. no need to mess about with wires etc.
Post #44894 10th Nov 2010 6:11pm
mse
Unfortunatley doesnt solve the problem though. Plus you would also use this WITH a split charge and there are many scenarios when a split charge just wouldnt apply (some deep cycle batteries cant start the car anyway!)
Dont get me wrong - i just thought some people may be interested in the device
I may get one, but wasnt on my radar - seemed cheap at �70 Mike
Post #44901 10th Nov 2010 6:35pm
BigMike
yeah i agree, it does seem like a great device. i wasnt meanng to come across otherwise
Post #44910 10th Nov 2010 8:26pm
Vixen
Australia
Personally, myself, I have always run 2 batteries wired to an isolator switch that allows you to run everything off one battery, both batteries or the second battery. Found it more economical to run 2 start batteries rather than a deep cycle as the second battery.
You can run an Engel fridge for 3 days on a battery in Aust without flattening it (in an extreme heatwave maybe 2 days)....so with running 2 batteries you are safe for 4 days basically, including stuff like charging camera & laptop batteries.
Post #44912 10th Nov 2010 8:49pm
BigMike
an engel fridge should cut out way before it flattens a battery.
Post #44913 10th Nov 2010 8:50pm
Vixen
Australia
Never tried it. No-one wants cold beer anyway at the end of a summers day in Oz Laughing
Post #44914 10th Nov 2010 8:51pm
