Home > My Defender > My next Project 90 Hardtop to soft top
Page 3 of 4 <1234>
jst
it would take me more than a hour to fit that lot which is about what it gets a day currently!
thank you for sorting paint job, looking good and back to unit now work to do! Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #519981 1st Apr 2016 2:03pm
willo
I think we need pics of the respray Cool
Post #520278 2nd Apr 2016 1:46pm
jst
now some work to do! Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #521009 4th Apr 2016 10:51pm
CY88
1986 Defender 90 V8 Petrol ST Keswick Green
Very nice. Look forward to seeing it come together Thumbs Up
Post #521012 4th Apr 2016 10:59pm
pjb
Looking good Thumbs Up
I was deciding on whether to go for black splats - or what ever they are called or body colour - having seen yours, I think body colour is the way to go - cheers
Cannot wait to see the finished result 2020 P300 HSE
Post #521042 5th Apr 2016 7:22am
jst
my only rear regret is the rear quarters, but they were damaged enough they had to come off. so be it i guess. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #521324 5th Apr 2016 8:45pm
jst
starting to add bits back on now (after trial fit)
Exmoor Trim rear mat system and bench seat and belts each side
added some tie downs - 3 each side to, bound to need them and the help secure the mat.
Hood frame is on, Safety Devices bit on rear and the Exmoor Trim powder coated black front cab bits, cant remember what they are called!
chq plate, winch etc to go and the hood and wheels to change
on another note, rebuilding the front hubs, anyone used the Britpart swivel kits including the new deisgned top king pin! what a backward step, the inner part of th bearing is part of the pin and the outer bearing - debatable quality! photo of timken for comparison with more roller too.
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #521970 7th Apr 2016 6:58pm
Nice to see the hood bits on. The more I see them, the more I want one.
Britpart, it's just not worth it. I've bought stuff, turned up as Britpart.... I saved myself a whole heap of trouble and just put it straight in the bin. CBA even to return it.
Post #521983 7th Apr 2016 7:30pm
LR90XS2011
James lovely job
ditto everything I've had that has been in a Britpart bag or box has been good for nothing but scrap its cheap for a reason DEFENDER 90 TDCI XS,
Post #521985 7th Apr 2016 7:34pm
jst
i concur on Britpart currently, unless it has OEM next to it! Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #522133 8th Apr 2016 9:12am
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
I Agree re the Britpart stuff, pure sh...... even if it has OEM stamped on it ... I still don't feel comfortable opening that little blue bag Rolling with laughter
Nice rebuild jst, hope mine will look half as good when its finished
N.
Post #522247 8th Apr 2016 1:51pm
jst
chq plate on the wing tops now and the channels fitted on the windscreen and the rear tub to take the hood.
winch is on the front too. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #523285 12th Apr 2016 8:26am
jst
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #523287 12th Apr 2016 8:28am
jst
fitted snorkel yesterday as well. it joins into on the Nugget sealed intake systems.
I had to cut down the tabs slightly on the mounting bracket of the Mantec and bend them open a fraction to account for the extra thickness off the nugget box behind the wing.
it pays to hoover out the inside of the snorkel, plenty of manufacturing debris in there prior to me cutting/changing anything!
i used lots of sealent for wing to to foam, foam to snorkel and backing plate to snorkel and snorkel itself to the wing. once its gone off will see how well its sealed by checking the top and limiting air flow!
CB antenna undecided on where to put yet.
winch needs wiring in to in cab (elec window) switch.
found some new boots for it too! Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #523290 12th Apr 2016 8:32am
jst
getting there, trial hood fit.
new boots are on 285.75R16s on std boosts no spacers. lock is better than my 110 so happy with that.
i need to move the Z channel down a bit to make it tighter on the sides/back. Hood will come off again to sort so final frame bits. plus still need to add snorkel pics.
first bad bit turned up - been running her a few miles to try and highlight problems. seems something must be wrong here:
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #524321 15th Apr 2016 8:06pm
Page 3 of 4 <1234>
