Home > In Car Electronics > Dash Cam with reverse Cam option in a single DIN unit?
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
Hey peeps I see you can now get single Din units with reverse Camera. Does anyone know if you can get a Single Din unit with both dash cam front and rear with the rear also being a reverse cam??
Like the looks of the Blackvue 650 truck dual cam but don't want to run 2 cameras if I don't have too but would like the reverse camera function.
Post #506316 19th Feb 2016 10:56pm
Edzi
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Alaska White
A dashcam is a separate unit and as far as I know, there are no head units that have a dashcam facility. You can attach a second camera to some, but this doesn't act like a dashcam which records in a loop.
As for the single DIN with reverse camera, there are a few on the market, but the problem I found when doing my research a couple of months ago, is that they all use old software and don't have full integration with iOS or Android. I did find one unit though which does:
http://www.pioneer-car.eu/eur/products/avh-x7800bt
I decided to go double DIN in the end as I wanted DAB as well and couldn't find a single DIN that had all I wanted. If I were to drop the DAB requirement, I would have gone for this Pioneer.
Post #506321 19th Feb 2016 11:24pm
dave18
Edzi,
Cheers I've found several Single Din running android / IOS with reverse Cams! Was wondering if anyone has came up with a all in one. As loads have built in GPS and rear cam how much work would be involved in having a second camera and memory function?? Might just get the Blackvue650 and a head unit with reverse Camera then. Unfortunately can't run Double Din on a raptor dash it's about the only downside to them.
Post #506355 20th Feb 2016 9:56am
