Home > In Car Electronics > Dash Cam with reverse Cam option in a single DIN unit? |
Edzi Member Since: 20 Sep 2015 Location: London Posts: 279 |
A dashcam is a separate unit and as far as I know, there are no head units that have a dashcam facility. You can attach a second camera to some, but this doesn't act like a dashcam which records in a loop.
As for the single DIN with reverse camera, there are a few on the market, but the problem I found when doing my research a couple of months ago, is that they all use old software and don't have full integration with iOS or Android. I did find one unit though which does: http://www.pioneer-car.eu/eur/products/avh-x7800bt I decided to go double DIN in the end as I wanted DAB as well and couldn't find a single DIN that had all I wanted. If I were to drop the DAB requirement, I would have gone for this Pioneer. |
19th Feb 2016 11:24pm |
dave18 Member Since: 11 Jul 2015 Location: Gorleston, Great Yarmouth Posts: 497 |
Edzi,
Cheers I've found several Single Din running android / IOS with reverse Cams! Was wondering if anyone has came up with a all in one. As loads have built in GPS and rear cam how much work would be involved in having a second camera and memory function?? Might just get the Blackvue650 and a head unit with reverse Camera then. Unfortunately can't run Double Din on a raptor dash it's about the only downside to them. |
20th Feb 2016 9:56am |
