Home > In Car Electronics > has the main dealer F@&K£% something??!! NANOCOM expert
dumptruckface
England 2012 Defender 110 Puma 2.2 XS DCPU Orkney Grey
ok so i got a nanocom today and on connecting it up there are some items that im wondering if they are correct or not, when im looking at the live engine data, and inputs im not geting what i would expect to see (im assuming these inputs are live and should change as the value of said input changes?)im getting the following
alternator lamp - ON (should this be saying its on?? i have no alternator warning lamp on?
Crank reference fault - ON!??
water in fuel - ON!!??
A/C request - OFF even when i turn the A/C on??
A/C pressure high- ON
A/C clutch - ON
Ignition status - OFF (even tho the engine is running)?
Starter motor enable - ON even thos the engine is started and running.
Brake light input -OFF and brake light - OFF even when i push the brake pedal and the rear brake lights are on, or the handbrake light is on.
its hshowing my coolant temp as -40
and my inlet air temp as -28!!
and lastly its showing my fuel tank volume as 0 zero.
im getting concerned as the dealer managed to put a dead short across my battery at the begining of the week which caused a small fire (in their words) its all fixed and i have no evidence of any problems except im now wondering if they have damaged something, or in fact these weird readings are just the nanocom not doing its job properly? im stuck and concerned at the same time.
Does anyone have a tdci 2.2 puma in Taunton that wants me to hook a nano com up to so we can compare readings? or even better does anyone locally have nanocom and experience with it?
Post #506224 19th Feb 2016 7:11pm
You could try asking Gary @ Alive tuning. Maybe worth a shot, if he can't help with the Nano then could make give you some ideas.
Post #506228 19th Feb 2016 7:22pm
mk1collector
Have you asked on the nanocom forum? Ray
My build thread
Post #506240 19th Feb 2016 7:55pm
