Home > My Defender > Interior Inspiration Required for my ode 90
Page 1 of 3 123>
Woody3
United Kingdom 1989 Defender 90 200 Tdi HT Bronze Green
I'm after some inspiration for the interior of my 90.
Currently it's pretty standard and to be fair I'm not wanting it to change much...just make it a tad more modern and comfortable Whistle .
So far this is what I have done:
Soundproofed the cab and wheel arches
Padded out the sides to the rear
In the process of buying a cubby box
I'm hoping to be doing a bit of Camping in the Landy in the new year, so I'm wanting to get the interior has nice as poss. I'm thinking along the lines of:
XS heated seats
Decent Head Unit and Speakers (nothing OTT)
Cradle for my HTC Phone and enable it to charge (probably via USB to laptop?)
Possibility of connecting laptop for it to charge and to phone (for Internet access for Navigation Purposes)
Use of Cargo Net jobbo's
Trim for around windows that are located either side of the rear door.
Storage ideas, but allowing me to put dogs in back still
Basically I'm after ideas of how to go about it, as I'm sure some of you guys have already done something similar. Please note my Landy isn't an hardcore off roader, I'm just after a bit of a modern twist if you will.
I look forward to your proposals Thumbs Up
Post #44579 7th Nov 2010 7:34pm
Woody3
Anyone? Crying or Very sad
Post #44692 8th Nov 2010 9:02pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
for living out of your defender the best thing i ever did was make, not buy as i haven't won the lottery, but make, ashelf that its at wheel box height and has a drawer under it, and as you get so much height in the back of the defender you can add a shelf that sits in the roof to side lip and gves you more storage optionsfor all the light but bulky iteams, sleeping bags, coats and such like, makes life so much easyer and very simple to make yourself.
not sure what spec your defender is but if you dont have a cubby get/ make one, well worth it.
Post #44718 9th Nov 2010 10:01am
Woody3
I have a cubby box on it's way to me as we speak. Should be with me by tomorrow Smile Thumbs Up
I quite like the idea of both the drawer system and shelf. Do you have any photos of yours? I assume made out of MDF and cover it in carpet/vinyl?
This might sound daft, but how did you get the upper shelf into the Defender, as the door is pretty small compared to the actual width of the cab (had a problem with this before!) Laughing
Is it just a case of going in diagonally?
Post #44725 9th Nov 2010 11:07am
bigee
Wales 2002 Defender 90 Td5 Braemar LE Blenheim Silver
Or....more likely,make it in two halfs to fit in,even cover said two halfs seperately to give you the option of 'full' or 'half' shelf. Very Happy
Post #44762 9th Nov 2010 3:02pm
double cab happy
the shelf is box section with weld'd mesh on to (mesh will bend a bit) and shelf/box is made from 18 mm WBP ply as MDF will not like getting wet, i also run straps from the shelf down to the removed tie down points and bolted it in place, so no holes drill'd.
Post #44821 9th Nov 2010 9:58pm
Woody3
Don't suppose you have any pics of the installation do you? Whistle
Post #44840 10th Nov 2010 12:10am
landy andy
Mine
Post #44851 10th Nov 2010 8:49am
dgardel
Italy
Same ideas.........
AND the last addition
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #44854 10th Nov 2010 9:02am
Woody3
Andy, that is just what I am after - looks great!
Thanks everyone else...I am now drawing up plans Thumbs Up
Just need some seats now!
Post #44985 11th Nov 2010 7:57pm
BruceT
South Africa
Wow. I like the outside temp gauge. Where did you get it and can I order one from them?
Thank you
Post #47200 3rd Dec 2010 6:18am
Paullr90
United Kingdom 2003 Defender 90 Td5 XS CSW Bonatti Grey
Hi dgardel, I like the look of your temperature sensor as well. Looks like a factory fit rather than some cheap add on. Any details on where you got it from?
Paul
Post #57253 6th Feb 2011 9:02pm
wobble_hd
landy andy wrote:
Mine
Is it possible to see more of your screen installation?
Regards
m
Post #57564 7th Feb 2011 9:30pm
jst
how old is olde? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #57569 7th Feb 2011 9:35pm
landy andy
Andy
Post #57579 7th Feb 2011 9:58pm
Page 1 of 3 123>
