Home > My Defender > Interior Inspiration Required for my ode 90 |
Woody3 Member Since: 13 Jan 2010 Location: Derbyshire Posts: 415 |
Anyone?
8th Nov 2010 10:02pm |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 |
for living out of your defender the best thing i ever did was make, not buy as i haven't won the lottery, but make, ashelf that its at wheel box height and has a drawer under it, and as you get so much height in the back of the defender you can add a shelf that sits in the roof to side lip and gves you more storage optionsfor all the light but bulky iteams, sleeping bags, coats and such like, makes life so much easyer and very simple to make yourself.
not sure what spec your defender is but if you dont have a cubby get/ make one, well worth it. |
9th Nov 2010 11:01am |
I have a cubby box on it's way to me as we speak. Should be with me by tomorrow
I quite like the idea of both the drawer system and shelf. Do you have any photos of yours? I assume made out of MDF and cover it in carpet/vinyl? This might sound daft, but how did you get the upper shelf into the Defender, as the door is pretty small compared to the actual width of the cab (had a problem with this before!) Is it just a case of going in diagonally? |
9th Nov 2010 12:07pm |
bigee Member Since: 24 Oct 2010 Location: middle of nowhere... Posts: 78 |
Or....more likely,make it in two halfs to fit in,even cover said two halfs seperately to give you the option of 'full' or 'half' shelf.
9th Nov 2010 4:02pm |
the shelf is box section with weld'd mesh on to (mesh will bend a bit) and shelf/box is made from 18 mm WBP ply as MDF will not like getting wet, i also run straps from the shelf down to the removed tie down points and bolted it in place, so no holes drill'd.
9th Nov 2010 10:58pm |
Don't suppose you have any pics of the installation do you?
10th Nov 2010 1:10am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5575 |
Mine
Click image to enlarge |
10th Nov 2010 9:49am |
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Same ideas......... Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge AND the last addition Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
10th Nov 2010 10:02am |
Andy, that is just what I am after - looks great!
Thanks everyone else...I am now drawing up plans Just need some seats now! |
11th Nov 2010 8:57pm |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 517 |
Wow. I like the outside temp gauge. Where did you get it and can I order one from them?
Thank you |
3rd Dec 2010 7:18am |
Paullr90 Member Since: 06 Feb 2011 Location: Derby Posts: 93 |
Hi dgardel, I like the look of your temperature sensor as well. Looks like a factory fit rather than some cheap add on. Any details on where you got it from?
Cheers Paul |
6th Feb 2011 10:02pm |
wobble_hd Member Since: 26 Feb 2008 Location: Norway Posts: 18 |
Is it possible to see more of your screen installation? Regards m |
7th Feb 2011 10:30pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7889 |
how old is olde? Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
7th Feb 2011 10:35pm |
Click image to enlarge Click image to enlarge Click image to enlarge Andy |
7th Feb 2011 10:58pm |
