Home > Technical > R380 gearbox fitting |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17367 |
Did you centre the driven plate correctly with a clutch aligning tool? Did you check the fit of the driven plate on the primary pinion shaft splines? Have you tried putting the box in gear and rotating the primary pinion shaft as you try to fit the box to the flywheel housing?
18th Feb 2016 5:51pm |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 574 |
Thanks for the quick reply blackwolf.
I fitted the new clutch using a suitable sized piece of wood to aligne the clutch. Is the primary pinion shaft the splined shaft on the gearbox???No...I did'nt check for fitting. The gearbox is in neutral,I have tried turning the crank pully,but it hasn't pulled together. Cheers Marc |
18th Feb 2016 5:57pm |
Rich broom Member Since: 26 Jul 2015 Location: Tiverton Posts: 78 |
Did you burr over the spigot Bush when fitting it. ?
18th Feb 2016 6:15pm |
No,I checked with my finger after fitting it.
Thanks. |
18th Feb 2016 6:19pm |
It's possible that the driven plate won't fit onto the PP shaft splines, this would cause your problem. It's also possible that the PP shaft is jammed hard enough against the clutch or flywheel to mean that when you turn the crankshaft you're actually turning the shaft as well, which is why I suggest putting it in gear and turning the gearbox shaft not the crankshaft.
If that doesn't do it I'd be inclined to pop it out again and check that everything is ok rather that use force. Sometimes a vigourous rattle of the box sorts it . The primary pinion shaft is the shaft that sticks out of the front of the box into the clutch and carries - you've guessed it - the primary pinion at the back end inside the box (the PP is the gear that is in constant mesh with and drives the layshaft). |
18th Feb 2016 6:58pm |
The double post gremlin strikes again!
18th Feb 2016 7:04pm |
Thanks BW
I'll put the gearbox in gear & diflock tomorrow,then try again. Marc |
18th Feb 2016 7:06pm |
Well after 3 hours of pushing pulling & swearing,my new clutch is in.
Thanks to all who replied with suggestions. BUT......I looked in the box that had the clutch fork in it & found a little plastic clip.The square thing in this link. http://www.johncraddockltd.co.uk/land-rove...-bush.html Can anyone tell me where it go's. I hope I don't have to strip it all down again to put it in. Thanks Marc |
19th Feb 2016 4:37pm |
If you mean the little black thingy it clips the pushrod to the outer end of the fork.
19th Feb 2016 6:07pm |
