Home > Puma (Tdci) > Door Seals |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 |
Hi All,
I've noticed that the door seals are not as efective as they were last winter - got a bit of a breeze coming in on most doors and when the waggon was being cleaned recenly water from a pressure hose came in and drenched my passanger! (just as wel the heaters are good!) So - how can I re-seal the doors seals Do I need to replace them or is it a case of adjustmnet some how... I cant belive the the seals have worn out as the waggon is just 3 yrs old. any thoughts? Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
6th Nov 2010 6:58am |
Wyvern,
My rear door seal suffered the same. I used a silicone grease and wiped over the seal, it revives the seal and allows it to become soft/supple again. A pressure washer will always allow water past the seal if directly applied as they are not resilient enough Worth a try with the silicone grease though! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
6th Nov 2010 8:35am |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1588 |
My 110 rear door seals are terrible. The 110 is only 6 months old. The front door seals are sound.
6th Nov 2010 8:38am |
HI K9,
Many thanks for the tip - will try the silicone when I get home and see what happens this is one of a long line of 110's that we've had and the only one where the water comes in from a pressure washer so easily .. so a bit of a shock! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
6th Nov 2010 12:19pm |
Amos Member Since: 10 Oct 2010 Location: Northern Ireland Posts: 38 |
Being using this product for years.....!
http://cgi.ebay.co.uk/1Z-Einszett-Gummi-Pf...83fe62440a Its VERY good at what it does.....!!!!!!!! |
6th Nov 2010 4:42pm |
BigGeorge Member Since: 08 Aug 2009 Location: Zurich Posts: 43 |
or if you have no better idea how to spend your hard earned money you can buy a couple of these
http://nakatanenga-tours.de/shop/article_TDDLL-VR/Türdichtung-mit-Doppellippe-für-Defender.html?shop_param=cid%3D1%26aid%3DTDDLL-VR%26 note, price per door seal However, so far I've heard only good stuff. The goons are trying to bring me down! Defender 110 SW MY10 useless piece of ... but I like her Defender 90 V8 50th Anniversary Series IIa 109 / 6 cyl. ex-fire truck |
7th Nov 2010 6:07pm |
