Home > Puma (Tdci) > Door Seals
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Door Seals
Hi All,
I've noticed that the door seals are not as efective as they were last winter - got a bit of a breeze coming in on most doors and when the waggon was being cleaned recenly water from a pressure hose came in and drenched my passanger! (just as wel the heaters are good!)
So - how can I re-seal the doors seals
Do I need to replace them or is it a case of adjustmnet some how...
I cant belive the the seals have worn out as the waggon is just 3 yrs old.
any thoughts? Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #44443 6th Nov 2010 6:58am
K9F
Wyvern,
My rear door seal suffered the same. I used a silicone grease and wiped over the seal, it revives the seal and allows it to become soft/supple again. A pressure washer will always allow water past the seal if directly applied as they are not resilient enough Worth a try with the silicone grease though!
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #44444 6th Nov 2010 8:35am
RobKeay
My 110 rear door seals are terrible. The 110 is only 6 months old. The front door seals are sound.
Post #44445 6th Nov 2010 8:38am
wyvern
HI K9,
Many thanks for the tip - will try the silicone when I get home and see what happens
this is one of a long line of 110's that we've had and the only one where the water comes in from a pressure washer so easily .. so a bit of a shock! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #44456 6th Nov 2010 12:19pm
Amos
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Being using this product for years.....!
http://cgi.ebay.co.uk/1Z-Einszett-Gummi-Pf...83fe62440a
Its VERY good at what it does.....!!!!!!!!
Post #44472 6th Nov 2010 4:42pm
BigGeorge
Switzerland 2010 Defender 110 Puma 2.4 SW Keswick Green
or if you have no better idea how to spend your hard earned money you can buy a couple of these
http://nakatanenga-tours.de/shop/article_TDDLL-VR/Türdichtung-mit-Doppellippe-für-Defender.html?shop_param=cid%3D1%26aid%3DTDDLL-VR%26
note, price per door seal Big Cry
However, so far I've heard only good stuff. The goons are trying to bring me down!
Defender 110 SW MY10 useless piece of Censored ... but I like her
Defender 90 V8 50th Anniversary
Series IIa 109 / 6 cyl. ex-fire truck
Post #44568 7th Nov 2010 6:07pm
