Home > Maintenance & Modifications > Rear Mudflaps on a 110
Michaels Defender
United Kingdom 2013 Defender 110 V8 Petrol XS CSW Auto Orkney Grey
Just thought I would share my latest mod, I fitted some 90 mudflaps to the rear crossmember, is a very easy mod to do and other than series 109 vehicles I have not seen it been done before, I also made a guard with the old rear mudflap bracket added some rigid plastic sheet material which went up from the bracket and also I covert the internal end of the crossmember with another sheet of rigid plastic, any thoughts Question, its not a big job either to undo the work if need and return the flaps to the original postion.
Post #501557 7th Feb 2016 9:24am
mk1collector
It should stop the mud flap brackets snapping a section of 1/4 panel off like usual but to me it does look a little odd. Ray
My build thread
Post #501593 7th Feb 2016 11:11am
steve E
Wales
The only issue is now there too far back you'll get all the mud and muck in your cross member.
Post #501614 7th Feb 2016 11:34am
Michaels Defender
I have blanked of the rear crossmember with some rigid PVC sheet, similar to the Gwyn Lewis Kit, heres another view
Post #501630 7th Feb 2016 12:02pm
Al_The_Pal
2015 Defender 110 Puma 2.2 XS CSW Corris Grey
I think the mud flaps despite their name are just as important as spray suppression on the road, the distance between the wheel and the mud flap will be a deliberate feature along with each the ribs on the wheel side which channel the spray downward.
End result is that with more spray and poor output from standard LR rear lights your vehicle will be harder to see on dual carriageways in heavy rain.
Plus your departure angle has worsened and your likely to lose a flap on a slighter gradient than standar position
Post #501715 7th Feb 2016 3:09pm
ericvv
Looks just not right to me. Prefer the looks and the functionality of factory position which works fine as long as you also install the already mentioned reinforcement brackets.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #501720 7th Feb 2016 3:18pm
Stacey007
Hello
From a looks view straight from behind I guess it does look neater, however they look 'lost' and on a rainy day not sure how good they will actually be?
I like the idea as 90's look neater, but on the 110, sorry just something not right?
Post #501805 7th Feb 2016 7:07pm
Michaels Defender
I did take a while to get used to the idea, but I like it, hears a Kahn 110 with a similar idea
Post #501889 7th Feb 2016 9:17pm
1967jester
The Bowler ones look better & come with the bracket. They're a tad longer than OEM & thicker.
Available via a phone call & ask for Matt
Post #501898 7th Feb 2016 9:30pm
Stacey007
That's a 90 though? so looks right
Post #501901 7th Feb 2016 9:40pm
1967jester
Yes but better on a 110, they look great on my D4 & will be going onto Daisy when the restoration is done
Post #501902 7th Feb 2016 9:43pm
Likeomg
they will sell them if you call them up??? i know what I'm doing at 9 tomorrow...
any idea on price?
Post #501904 7th Feb 2016 9:49pm
