Home > In Car Electronics > 04 Td5 dim dip relay
dennisboast
United Kingdom 2003 Defender 90 Td5 HT Blenheim Silver
Can someone tell me where dim dip relay is on my TD5 90 2004? I have fitted led headlights, and dip lights are on when you turn the light switch on, I would like to just run side lights as I have fitted running lights, I only want the headlights to come on in the second position of the h/light switch. Many thanks for any help...[/b] Hard working recovery driver.
Post #501374 6th Feb 2016 6:31pm
Martin
Site Admin
Welcome to the site Smile
See http://www.defender2.net/forum/post473903.html#473903
The dim-dip relay is behind the instrument pack, and would require removing and bridging from pin 2 to pin 8 in the socket.
The relay is pink in colour Smile
Martin  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #501381 6th Feb 2016 6:42pm
dennisboast
Ok, thanks very much, I will look at that in the morning. Seems like when you fit led head lights they don't go dim, so have to switch it all the way. Many thanks again. Hard working recovery driver.
Post #501399 6th Feb 2016 7:25pm
Shiltmeister
Spain 2009 Defender 110 Puma 2.4 SW Alaska White
Hi
I have the same problem with a 2009 Puma. Do you know where the dip/dim relay is located in this instance?
Thanks 2009 Puma 110 SW
Post #502259 8th Feb 2016 7:01pm
Martin
Site Admin
On a RHD Puma it is on the wing under the bonnet near the brake booster. On the left as you look into the the engine bay.
LHD lighting looms might be mirrored so check on the opposite wing near the brake booster - right hand side as you look in.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #502270 8th Feb 2016 7:14pm
PaulMc
It's the large Pink relay, above the fuses -
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #502271 8th Feb 2016 7:14pm
Martin
Site Admin
Paul has it moved at some point in Puma production as I'm sure it has been said to have been on the wing?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #502273 8th Feb 2016 7:17pm
PaulMc
Martin, it's the dim/dip resistor that's mounted to the o/s inner wing -
Post #502278 8th Feb 2016 7:21pm
Martin
Site Admin
Censored !
Cheers Paul I will try to remember that Embarassed  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #502280 8th Feb 2016 7:22pm
PaulMc
Martin
To remove dim/dip, you can bridge the contacts in the dim/dip relay base (C0048) -
Or, if you want to do it the way Land Rover do it, use the dim/dip by-pass dummy relay YWZ10003L -
Post #502282 8th Feb 2016 7:26pm
Shiltmeister
Thanks guys. Its a LHD so ill check the resistor under bonnet. I presuming I just need to bypass it. 2009 Puma 110 SW
Post #502283 8th Feb 2016 7:27pm
Martin
Site Admin
Yes I said bridge in the socket Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #502284 8th Feb 2016 7:27pm
Martin
Site Admin
Better to bridge the pink relay as Paul shows above.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #502286 8th Feb 2016 7:28pm
Just unplug the resistor. Nothing else is needed.
Post #502300 8th Feb 2016 7:39pm
Shiltmeister
Well this is the view under the column on my LHD version.
The big pink one is the wiper relay as proven when bridged.
The resistor also seems to be hidden away somewhere. Its not obvious to see under the wings. I thought it would be around where the arial is on drivers side. Maybe I need to dig under the heater intake which fills the passenger side wing. Time for a beer.
:thud:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2009 Puma 110 SW
Post #502340 8th Feb 2016 8:31pm
