Home > Maintenance & Modifications > Connectors on RDX LED sidelights.
leonski
I have just fitted the RDX sidelights to the 90 and was wondering if it was just me or are the connectors rubbish?
I was wondering if it is best to cut both of and get some good old insulated spade connectors?
Cheers,
Leon.
Post #500050 3rd Feb 2016 8:27pm
They are the same as Genuine and waterproof if fitted correctly.
Pre ins spades would be useless and will corrode and get wet.
And I definitely wouldn't advise cutting off the OE fitted plugs, which is why they are used to be plug and play.
Your vehicle, your choice though.
Thumbs Up
Post #500060 3rd Feb 2016 8:50pm
Yeah Leon, they suck!!
Post #500061 3rd Feb 2016 8:54pm
leonski
It not that I want to cut them off, but how the hell do you get them and their little rubber seals firmly into the back of the connector!
Post #500063 3rd Feb 2016 9:00pm
Orangesofa
United Kingdom 2013 Defender 90 Puma 2.2 SW Keswick Green
I doused the inside of mine with ACF50 as I fitted them just to be on the safe-side. Phil
Post #500067 3rd Feb 2016 9:09pm
Orangesofa
I found that they slipped in fine one way and not the other. Obvious really but did you try flipping them 180 degrees and trying them? I replaced 8 units 2 weeks ago and it took me 15 mins. Phil
Post #500074 3rd Feb 2016 9:32pm
leonski
Yes, I realised that, but one has a terrible connection and they just don't seem very robust!
Lights are great quality though!
Post #500080 3rd Feb 2016 9:36pm
Ah I know the issue you mean!
I fitted the seals with the tapered end towards the terminal.
I crimped the cable sheath tabs to include the seal taper too holding it in place.
On top of that used a small screwdriver to push the seals in just a small touch to make a tighter seal and finished the job off with a tiny touch of super glue to keep everything in the exact position as fitted.
Some people have also soldered the terminals, I personally didn't and have had no problems.
If you've got a dodgy connector which they can be they are best binned and buy a new one.
Post #500089 3rd Feb 2016 10:08pm
leonski
Thanks Steve!
I now don't feel so inept!
I will try crimping and pushing them in with a screwdriver....and if all else fails I will buy some more connectors!
Cheers,
Leon.
Post #500205 4th Feb 2016 9:09am
Happyoldgit
Undertaking the job when the temperature is up [ie warm] helps a lot, the plastic and rubber inserts get stiff in the cold. Steve.
http://forums.lr4x4.com
Post #500214 4th Feb 2016 9:58am
^^^^ Very true, keep them in the house and do it there and go out once ready then fit.
Post #500245 4th Feb 2016 11:01am
Martin
Site Admin
They don't fit the connectors for you? Shocked
I assume the connectors are these?
  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #500246 4th Feb 2016 11:04am
RRUK
That's the type Martin.
I found that to get the metal spade through the holes in the yellow plastic part was fiddly, and needed some teasing.
As said above, they go in one way and click in, and the other way they don't. After you've done a couple it becomes second nature.
Nothing with a Defender is easy, remember that! 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #500271 4th Feb 2016 11:34am
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
Yes they are. the come with connectors crimped to the wires. The connectors are not assembled as the wiring on the lights has different polarity on different models. This enables you to match polarity before assembly. You do need a small tool to push the contacts home and then fit the yellow moulding inside the body. Note that this piece and the contacts will only all fit together one way round. 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #500272 4th Feb 2016 11:34am
Martin
Site Admin
OK, just wondered as there was some mention of crimping terminals on.
The terminals should be fitted into the "bare" black housing, they will only fit one way around and must be "square" to the housing to go in.
The yellow lock is then fitted at the end. This can be fiddly as you are trying to pass it over thin blades buried down in the housing. It should then be pushed all the way down into the housing with a prodding device (screwdriver).
I've fitted plenty of these and they are no better or worse really than any other connector Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #500278 4th Feb 2016 11:40am
