Home > Puma (Tdci) > Add a new toy for the winter |
http://cgi.ebay.it/1999-LAND-ROVER-WOLF-/1...500wt_1156 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
3rd Nov 2010 8:56pm |
by the way.....
original LR solution on winterized Wolf Click image to enlarge Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License Last edited by dgardel on 3rd Nov 2010 9:08pm. Edited 1 time in total |
3rd Nov 2010 8:59pm |
3rd Nov 2010 9:03pm |
Thanks to TRRMOTORSPORT (a new Defender2 member)
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
3rd Nov 2010 9:06pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
What is that on the Engine Air Intake. Not clear in the photo???
4th Nov 2010 4:47am |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
That is the millitary cover...... not many have them now as most have snorkels It is designed so that splashed water/ mud can't enter the intake. Another thing on the heater inlet cover... they are used in hot climates to stop sand ingress when you have sand storms. Glyn P.S. I WANT ONE!! |
4th Nov 2010 8:28am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2445 |
Im looking for the opposite for the summer: lots of air for air flow. Blue print still in my head . I guess fiberglass will be the first prototype. Puma 110" SW
4th Nov 2010 8:36am |
Something like this? Glyn |
4th Nov 2010 8:40am |
Thanks, but not sure if they do the job. Need to be higher. Mi idea i like the winter type shwn on these pages but longer up to the front end wing and facing forward . We just add a couple of days with 33ēC.....
A snorkel top would probably do the job but it´ll look ugly. All thanks to Mr Bl00dy Ford! Puma 110" SW ............................................................. Earth first. Other planets later Last edited by MK on 4th Nov 2010 9:02am. Edited 1 time in total |
4th Nov 2010 8:56am |
I have just come across this one which I must admit even I like (I don't normally like the forward facing ones). Also is in the US so will probably be easier for shipping for you- a lot cheaper than the KBX ones too
http://americandirtroads.com/catairintakes.html I even like their snow one. Glyn |
4th Nov 2010 9:01am |
Good tip Puma 110" SW
4th Nov 2010 9:06am |
BigGeorge Member Since: 08 Aug 2009 Location: Zurich Posts: 43 |
Snow Cover (fresh air). I have the one from Blanchard. Works perfectly in Winter and looks cool in summer. If you get a lot of snow (like we do occasionally in Switzerland) a decent snow cover is required in particular if you a Webasto Car-Pre-Heater or similar installed. You don't want to go out in your undies to clean the air intake, do you...
What's the purpose of this chunky military engine air intake on the side? does it do any better job than the stock one? Cheers George The goons are trying to bring me down! Defender 110 SW MY10 useless piece of ... but I like her Defender 90 V8 50th Anniversary Series IIa 109 / 6 cyl. ex-fire truck |
4th Nov 2010 9:45am |
4th Nov 2010 1:23pm |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2672 |
Do the winterised versions not have extra heater/rad in the rear crew compartment? So you wouldn't notice a loss in performance. They must work or the MOD wouldn't buy them or perhaps the salesman was good 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
4th Nov 2010 2:07pm |
