Home > Off Topic > Workshop heater
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Workshop heater
What do you guys use ?
I currently use a Propane space heater,
A bit noisey, a bit hot and not ( warms up ok, but gets cold quick after its turned off )
Not ideal for painting bits either
I have a good electrical supply if required
The garage is a healthy double, in width and length, I can drive a 90 in and park it at 45% with all doors open ect,
Not used every day, and requires to warm up quite quickly,
What's ya thoughts chaps ??
Thanks in advance
Post #494128 19th Jan 2016 6:34pm
Cupboard
We use a waste oil burner, but that's probably not very helpful for you.
If the space is badly insulated, whatever heater you use the space will cool down quickly when you turn it off.
Post #494413 20th Jan 2016 1:14pm
mcma1
Post #494422 20th Jan 2016 1:35pm
Stacey007
As I like anything free and always looking for wood / pallets I would look at a log burner Smile
If its a garage attached you your house in the last house we had I had this split into two room and had rads installed, guess this means you would need the house heating on though but it worked well.
I insulated the walls with stud wall and insulation around 100mm thick also though Smile
Post #494444 20th Jan 2016 2:42pm
Rsmont92
I would improve the insulation first. It will also keep it cool in the summer
Post #495361 22nd Jan 2016 10:00pm
