Home > Off Topic > Workshop heater |
We use a waste oil burner, but that's probably not very helpful for you.
If the space is badly insulated, whatever heater you use the space will cool down quickly when you turn it off. |
20th Jan 2016 1:14pm |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2899 |
this is mine, great bit of kit.
http://www.sealey.co.uk/PLPageBuilder.asp?...ctid=14098 Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
20th Jan 2016 1:35pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3757 |
As I like anything free and always looking for wood / pallets I would look at a log burner
If its a garage attached you your house in the last house we had I had this split into two room and had rads installed, guess this means you would need the house heating on though but it worked well. I insulated the walls with stud wall and insulation around 100mm thick also though |
20th Jan 2016 2:42pm |
Rsmont92 Member Since: 27 Sep 2015 Location: Bristol Posts: 65 |
I would improve the insulation first. It will also keep it cool in the summer
22nd Jan 2016 10:00pm |
