![]() | Home > Puma (Tdci) > Drive Train Wind Up |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
I just noticed the last two times I jacked up the rear axle (both sides) that the wheel being lifted spun back a couple of inches as if there is wind up in the drive. Is this normal on the permanent 4x4?
This is long after the vehicle was last in diff lock - unless the light could be a faulty. I would suspect however that you would notice if you were in diff-lock on the tar. My series doesn't run on both props so I never took note of this before. Apretiate some comments Puma 110 - gone Series III 1973 - going strong |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5086 ![]() ![]() ![]() |
Normal in every LR i have had, however, some of it is jacking on a slight slope Mike
thanks Puma 110 - gone
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8208 ![]() ![]() ![]() |
definitely normal Cheers
