Home > Puma (Tdci) > Drive Train Wind Up
CapeLandy
South Africa
Drive Train Wind Up
I just noticed the last two times I jacked up the rear axle (both sides) that the wheel being lifted spun back a couple of inches as if there is wind up in the drive. Is this normal on the permanent 4x4?
This is long after the vehicle was last in diff lock - unless the light could be a faulty.
I would suspect however that you would notice if you were in diff-lock on the tar.
My series doesn't run on both props so I never took note of this before.
Apretiate some comments Puma 110 - gone
Series III 1973 - going strong
Post #2955 29th Jul 2008 6:21am
mse
Normal in every LR i have had, however, some of it is jacking on a slight slope Mike
Post #2956 29th Jul 2008 7:13am
CapeLandy
South Africa
thanks Puma 110 - gone
Post #2957 29th Jul 2008 7:21am
jst
definitely normal Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #2983 30th Jul 2008 7:52pm
