Home > Maintenance & Modifications > remap
machine1963
England 1985 Defender 90 300 Tdi SW Tonga Green
remap
Do defender owners get remaps done before warenty ends or do they hang on.
Post #492579 15th Jan 2016 12:57pm
PDH
Got mine done within a few weeks of picking it up brand new but others wait, it depends how you feel about such things.
There are options to return it to normal so the garage wouldn't know, I used Pete @ BAS for this reason (along with quality of his work and have had other defenders done by him over the years) Puma 2.2 90 Stationwagon
Post #492583 15th Jan 2016 1:07pm
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
Yep do it before warranty expires, if it's got to go back to stealers just put back to standard Thumbs Up
Post #492586 15th Jan 2016 1:14pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
I've got a second tuned ECU from Gary at Alive and just stick the factory ECU in before it goes in for servicing or warranty work 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #492591 15th Jan 2016 1:19pm
TJ101
I also got a new ecu to go with the map from Pete at Bell,, so the original one that came with the Defender is untouched
After the 2.4,, could not live with the 2.2 without it Thumbs Up California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #492603 15th Jan 2016 1:38pm
McGeordie
United Kingdom 2014 Defender 110 Puma 2.2 USW Montalcino Red
^^^^^ same here, OEM ECU retained mapped via additional ECU from Pete at BAS Very Happy Sold Def 90 HT 2010...Stornaway..(SOLD in Oct 2014)
Current: delivered October 2014:- 110 USW XS.....Montalcino Red
Post #492615 15th Jan 2016 2:09pm
Why are you guys needing another ECU? I'm assuming you mean a phisical fit / swap over?
Mine which is Alive with ATRIC device you can just swap between standard and tuned map using the device.
So just plug in and swap over, mine you it's something I never do and never needed to do but the option is there.
Post #492731 15th Jan 2016 7:06pm
You can't do that with a 2.2!
Post #492740 15th Jan 2016 7:30pm
Riccarton
Scotland 2012 Defender 90 Puma 2.2 HT Zambezi Silver
Can't do what? My BAS RRC allows me to swap between maps Thumbs Up
Post #492742 15th Jan 2016 7:37pm
Is the RRC a similar device? I didn't notice that we were talking 2.2's here as mines a 2.4.
I thought the two would be fairly similar bar DPF, of course there will be some differences though electronically and philsically.
Post #492745 15th Jan 2016 7:43pm
PDH
Mine does too but LR can tell that it's been fiddled with apparently, unlike the 2.4 I had which they couldn't, hence why a second ECU is advisable if in warranty. Puma 2.2 90 Stationwagon
Post #492750 15th Jan 2016 7:58pm
machine1963
Is it about 160 hp with a remap without intercooler. Want things smoothing out low down.
Post #492755 15th Jan 2016 8:08pm
Riccarton
There's probably a lot more to this Thumbs Up
But first - I've had the 170 AB remap and it's great Thumbs Up Thumbs Up Pulls like a train - as in 4te plus trailer up a 1 in 8 and getting into 4th Thumbs Up I'm sure I can feel the drive flanges crying enough Laughing It's very smooth from tick-over upwards and no kangerooing. Once the weather starts to warm up I'll add the intercooler just to help it out a bit.
Getting a remap isn't always such a big issue to the stealer. In the past I've bought vehicles (TD5s) and then taken them back to the stealer for a remap. You pay a wee bit over the odds but the warranty issues then becomes the stealers problem. It just depends on the friendliness and customer appreciation of the stealer I guess.
If you get a replacement ECU and swap it everytime it goes in the stealer will be aware as codes won't be logged - also, if something horrific happens and it needs the big yellow taxi how are you going to explain no faults logged even though it's s41t itself?
Just thoughts and I'm no expert - as you can probably tell Big Cry
Post #492796 15th Jan 2016 10:22pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
My 2.2 was mapped after the first 200 miles from Bas
Also have a Rrc tool great bit of kit highly recommended
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #492847 16th Jan 2016 7:34am
Morepower
New Zealand
Mines been done before I even collected it (BOWLER) Twisted Evil
Regards
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #492851 16th Jan 2016 8:22am
